0 Members and 23 Guests are viewing this topic.
alan
@fritz
To me, his last video shows proof of OU: energy in cap exceeds power delivered over time.
But where does it come from?
(coupling to the) earth, free ions, 'junk' EM waves (white noise, radio), space radiation?
Stiffler, what is your view on this?
thanks!
(I guess your website explains it, gonna give it a read)
professor
Quote from: fritz on October 31, 2008, 07:53:13 AM
On your website, you mention an article about an UWO created with a neg. resistor,
a certain length coaxial and a diode.
At least from the abstract - I wouldn´t derive the reverse situation that an UWO phenomenon
with a diode involved indicates a negative resistance....
What I see is an oscillator with a complex, non-linear feedback which includes somehow
a delay (intrinsic diode charge) and a near field EM coupling as outer fb loop.
Maybe this "feels" like a (differential) negative resistor - otherwise - there are no "single" pieces in
that circuit - everything is parasitary coupled.
The "negative resistor" mentioned in the article is per se no OU device (just to clarify).
It´s even possible to call every active part of an oscillator a negative resistor .....
In the normal run you use it just for oscillators driven by Gun or IMPATT diodes -
which have indeed a (differential) negative resistance of operated (powered) at certain
dc operating point. (Think thats what they use in this article)
Maybe I didn´t get the point....
rgds.
@fritz
That is exactly the way I see it also, but for reasons of being attacked for my views I will not get into Details.
I have played around with Tunnel Diodes in the 60's.
Here is a little abstract:
Under normal forward bias operation, as voltage begins to increase, electrons at first tunnel travel through the very narrow p-n junction barrier because filled electron states in the conduction band on the n-side become aligned with empty valence band hole states on the p-side of the pn junction. As voltage increases further these states become more misaligned and the current drops â€" this is called negative resistance, because current decreases with increasing voltage. As voltage increases yet further, the diode begins to operate as a normal diode, where electrons travel by conduction across the pn junction, and no longer by tunneling through the pn junction barrier. Thus the most important operating region for a tunnel diode is the negative resistance region.
I never got the Point
professor
nievesoliveras
Hi!
@professor
How can I get one of those SEC exciters you use to perform the experiments on your site?
Jesus
professor
Quote from: nievesoliveras on October 31, 2008, 03:37:56 PM
Hi!
@professor
Jesus
Hi Jesus,
Sorry I do not sell anything , unlike Stiffler ,I experiment using off shelf and old stock Parts.
However I do not believe in all the claims,neither is there an explanation of its fame.
It also is not as claimed selfrunning so what is the Point?
If you are into selling Boards ...............!
So if you are one of the believers in Stifflers magic Boards and you want to pay good money, you need to go to his
Website which you will find a few posts back.
professor
nievesoliveras
Hi!
@professor
I thought that you were Dr Stiffler.
I have gone to the links to his site on back post to no avail. It says no such site exists.
But thanks for the information.
Jesus
