0 Members and 42 Guests are viewing this topic.
Joh70
as long as a power supply or external powered signal generator is connected, i beleave nothing.
emitremmah
I am but a simpleton. I am still at a loss when I see one lead of a LED connected and it lights. I have laways been instructed that a circuit must come from somewhere and go somewhere. It doesn't. It is being lit by back EMF caused by the signal generator/oscilator because it seems to me that if you have a sine wave that the top is positive and the bottom negative then you are actually reversing the flow of electrons when you cross the base line. so what you are doing is then just exciting the electrons and that is enough?
Lost in the space between my ears.
An empty cup
abassign
Ops... :o
3. How for the wires which transports the current in the Avramenko experiment, the L2 thickness is extremely thin and is theoretically not sufficient for the current necessary to power 50 LEDs (50 * 20 mA = 1 A).
Is true... Clear this point...
But a little problem, why the LED or coil not burn ?
@Stiffler
Some time are the LED or Coil burned ?
samedsoft
@All
   I am trying to understand and analyse the principle behind Dr. Stiffler's circuit in depth;
   Please think about the correlation between them,
   http://www.nuenergy.org/experiments/modern_radiant_energy_circuit.htm
   http://www.peswiki.com/index.php/OS:Radiant_Energy_Antenna_System
   http://www.byronnewenergy.com/wiki/index.php?title=Ambient_Energy_Collection_Device
   http://peswiki.com/index.php/OS:Ambient_Energy_Collection_Device
   Dr. Stiffler has a lot of know how on this, und as I can understand he wants to go step by step and speak same language in the end. So it is very important to understand and analyze his previous videos and circuits.
k4zep
Hi All,
Well the troops are stirred up for sure.  Lets clear up a few things.  First, go to his site and read the whole article on his series of experiments and a lot of things will be pretty clear.  I believe Dr. Stiffler has a few theories that he is developing to explain how these devices work......time will tell.
The LED's are in series.  Current in my device is more in the 3-4 Ma. area.  I will know more when I get the correct coils.  Using his coil, I don't know what current he can force out of the packets of energy pumped through the 1N914's or equivalent.  Total voltage drop across the string times the current is the power developed in the string.
This is probably the best series of experiments using extremely high impedance and  possibly longitudinal waves in the RF region that I have ever seen!  Its all about matching impedances and something strange in the Barium Ferrite coil/coil configuration.  Theoretically, it gets complicated fast, way above me!
I want to thank the gentleman in Turkey for the heads up info on the LTC1799.  Sure wished they made it in standard configuration.  Does anyone make a small board/Osc. using this device out there as this should be a perfect driver for this device?  A resistor, a chip and a switch, how much more simple can it get and VERY low power too!!!!!  As is, you are going to need a magnifying glass to build this thing, my old eyes and shaky hands might be able to do it!  This should drive directly off a rectified output of a Stiffler device and with good decoupling, feed back and hence self run?  Hope so, sure would be fun to see it in my lifetime.
Anyway, lots of work to do.  BS is cheep, building and making it work is where the rubber meets the road.
Ben K4ZEP
