0 Members and 25 Guests are viewing this topic.
canam101
I have to say I am disappointed. I had high hopes for Stiffler's circuit because it was vouched for by a clever chap on another list.
But as far as I can see, this is just a way to use RF to light up diodes. Nobody has come up with the slightest evidence that there is more output from the circuit than there is input.
Stiffler would be the best one to do that, but all he does is tell people to toe the line or they will be 'out of the loop'. He claims 6 other people have replicated the circuit and have OU.  No evidence. Nothing from any of the 6, nothing from Stiffler.
Very disappointing.
c0mster
Also a function generator produces ac unless it has a DC offset so that it hits only + but a coil still has ac when it's hit with dc (electron interaction in substrate and magnetic field theory).
If you take 1 wire and plug it into a wall socket on one side of the plug and you are touching the earth you get shocked (DON?T TRY THIS).
Look at some power poles and you will see a ground rod attached to one of the lines.  1 wire power transmission is not uncommon. Tesla showed this, his work is used in many HV appliances. Today we are bombarded by mans RF and other radiating sources. Hence standing under High Tension Power lines with 2 florescent bulbs in ones hands. The secret to finding any new source or undetected source of energy is to insure you remove all what we have now back to before the 1900?s.
Once it is proven that you have removed all the dirt can you then get true clean measurements. If you used a satellite dish to listen to mars RF waves you would have to remove all other frequencies that are know and try to determine if what you hear is mars. A good understanding of the atom, electron and proton along with the complex relation between semi conductors, conductors and electron activity in said conductors is a start. Proving it by focusing on that theory and testing, one gains the understanding of much. If knowledge could be downloaded to ones brain without the daunting task of research, reading and experimentation we then would truly be on a higher plain of knowledge for all. There is always disappointment before success.
C
plengo
@EMdevices,
thank you for the reply. Can you send me a title for a good book on "RF" as you mention? I want to understand how RF can light up LEDs.
So, if RF can do this my question still stands (sorry for my ignorance), how this LEDs light up?, where is the energy coming from? And how is this different from the "Thomas oscilator"?
Fausto.
EMdevices
plengo
@EMdevices,
thank you my friend. I just purchased the one you mention. I will read and learn. Thank you for the explanation too. It seams so simples as you explained.
Does it means that the FG is "feeding" the LEDs with energy coming from itself? or it is a property of frequencies and coils? Sorry for my ignorance on the subject. It is that it seams logical for me that either the FG is giving some of its energy to the LEDs or it is coming from some place else.
Is it possible to measure this energy coming from the FG into the LEDs so that one can account for how much can I extract from it? It is very confusing to see a circut without closing the loop causing some energy to be used up without really coming from somewhere, unless one lead from the FG can give energy to the LEDs as in the video without closing the loop and therefore no current. But that's where I get confused how that is possible. (I have lots to read and learn).
If RF in classical Electrical Engineering can explain this phenomena I will be satisfied and I will not ask again.  Please, someone that understand this phenomena please just state here if this is the case.
Fausto.
