Rotation?
Started by BEP, October 11, 2007, 05:37:45 PM
Esa Maunu
If you have a rotating magnetic field in for example in a electric motor, so there is no field strenght amplification, even when the input power is in sync with the rotation. You see that there is a interferece in your setup?
Esa
Quote from: pauldude000 on October 12, 2007, 01:58:24 AM
Let me explain, as best as I understand the phenomena in my mind at this moment, and see if anything new turns up.
I think we are dealing with , for want of a better term, somewhat of a particle accelerator.
In a linear mode, the magnetic field would be viewable as starting at one end of the unit, then "zipping" down the length of the unit until it reaches the other end. Now, imagine a series of these toroidal shaped fields (imagine a long doughnut) propogating at the same time down the length of the unit.
In the center is a single thick wire. The magnetic field is penetrating but a small distance into the skin of this conductor, as it traverses the length of it. The field is not cutting the conductor, it is penetrating into it. The magnetic field, due to attraction and repulsion of the magnetic fields of the spinning electrons in the conductor, strips and pushes some of the electrons down the length of the wire in phase with the magnetic field. This leaves "holes" in the conductor, to which free electrons flow.
We now have an electrical gradient, or potential difference between the ends of the conductor. Since the fields are traveling in only one direction, free electrons can only flow in to fill the holes from one direction.
An electrical gradient is formed, from which useful power can be extracted. However limited this may be with a linear unit.
However, we are not talking about this effect in a linear unit. We are talking a circular path for the magnetic field to travel.
We then have a rotating magnetic wave which, until power is cut to the driving circuit, never stops traveling. Pass by pass it builds in strength, until the limitations of the driving circuit can no longer amplify the effect. As the field builds, it is able to strip more and more electrons. This means a higher potential gradient until maximum field strength is reached, which also limits the maximum number of electrons it is able to affect, and the maximum voltage gradient is achieved.
This rotating wave is dissimilar to the rotating wave principle that tesla based his induction motor upon. Imagine instead an example of the field of a toroidal (tube) shaped magnet with the ends magnetized, with a rod connecting the midpoint of the magnet to the center of rotation. You have a tube shaped field rotating around the center of rotation, with north and south ends always facing one direction, never reversing polarity........
This effect can ONLY be produced with pulsed DC. (A.C. reverses voltage polarity, therefore reverses field polarity and the effect never starts.)
The effect will ONLY complete more than one rotation if the circumference of the path is equal to a resonant length of the frequency used. (otherwise, the field would not be in the proper point in time to recieve amplification form the next pulse of the driver circuit.)
The collector coils MUST be resonant tuned to this frequency (or the applied signal will not be self amplifying in the collectors themselves, as significant back emf occurs cancelling out any pulse voltage or current summing.)
This effect could start on a miniscule scale, such as possible with only a small 9v battery and a couple of simple 555 timer driver circuits could provide. The effect would be due to signal summing through internal signal reflection in the collector coils. Two possabilities:
1. Imagine the end of the wire falling directly at the midpoint of a wave, in which there then causes a self amplifying standing wave in the collector. (Think possibly ungrounded collectors to achieve this.)
2. Two signals in the same wire, in which the higher frequency wave is exactly three times the frequency of the lower. (The rise and fall times of the lower frequency are precisely matched with the higher, therefore no cancellation of voltage at these points, and summing occurs.)
This effect could be quite dangerous, if too closely attuned. (Imagine a runaway self amplifying rotating magnetic field, which would only stop when the machine supporting it is destroyed, which the field strength itself would eventually do.....  :o )
How to control the field? Easy as pie. Slightly mismatch conductor lengths on one of the control coils. This will throw the field slightly out of sync, thus severely limiting the maximum field amplification.
Did this catch anyones attention?  ;D
Paul Andrulis
BEP
The question was who has done it and how.
So are you all saying that you have achieved this?
Good points though. The standing wave is already there. The only things needed are creating the gradient and keeping it just off center so it can be maintained.
Those messing with supposed Soliton generating coils - when you look straight down the end of your coil what do you see? If you didn't know it was so long you might think it was a torus would'nt you?
Does anyone on this forum understand that the 'field lines' (poor term) in and around a PM are not straight. When you do your iron filing on paper experiment they look straight. You need to look closer. Those iron filings don't lie flat on that paper. They are leaning on one end.
I'm worrying that I am actually living on Flatland as described by Carl Sagan.
giantkiller
The vortex or helix forms naturally in the direction pertaining to the north/south hemi. It is there fore just a simple matter to create a vertical potential difference / vacuum. All that has to be done is pull the plug and the direction will find itself.
Lets go one step further shall we?
If you create a spinning field of great intensity in a counterclockwise direction you could achieve a lightning strike. If you cause a clockwise rotation you could lift or alter matter. Duh. Can you say 'Hutchison effect'. He uses two spherical fields and one directional impact field at very high frequencies. He claims no control but the authorities have seen through this guise and repeatedly take his equipment. That does not stop him. He does it again, and again, again. So what is our congestion / contention?
Keely vibrated plasma to effect matter. Square waves shock matter into magno-electrical force. Telsa vibrated physical matter, magnetic fields, and the ionosphere to effect energy transmission.
We bang on keyboards hoping to fly away with the answer.
--giantkiller. I don't know it all but I am having fun finding out.
pauldude000
@esa
Yes, there is a rotational magnetic field in an induction electrical motor, and no there is no field strength amplification. This is due to three reasons.
1. The input driving source is anything BUT in sync with the field. (50-60hz AC is a very long wave, for such a very short conductor.)
2. The field is nonlinear, and is 90 degrees out of phase half of the time.
3. The driving source is AC and not pulsed DC, therefore back emf destroys resonance.
@BEP
Who has achieved this? Quite many, too a small degree:
Otto, Ronotte, Giantkiller, Jason (Jdo300), Camster6, just to name but a few, whether they knew it or not. I could tell because of the sound, as well as other effects.... (hunh?)
Yes, the sound. The warbling humming in their videos from their TPU's is a dead giveaway, of 2 things. Rotating field, and way too low of frequencies. The sound would be produced by the fields interaction with ions in the air. The charged particles in the air move due to the moving electromagnetic field.  If the frequency of this vibration is within the range of hearing, then it is audible. This effect is also noticeable with ac fields of high strength. (transformer hum for instance)
Each pass around the coil can be considered in hertz, with one rotation per second being 1 hertz. If it spins around the coil 100 times per second, you will hear a 100 hertz vibrational hum.
Listen to the tpu's in camster6's youtube and google vids, ginatkilleroverunity's "tpu sings" vids, and others. The control coils in these units are way too small considering the emf involved to account for the field strength necessary to induce the amount of ion movement (how loud the humming) to state that it is normal field hum for the applied current. Remember that field strength in a solenoid is due to number of turns and amount of current flow, in other words ampere turns. Not nearly enough turns, though in some cases almost enough current.
Why hasen't anyone obtained mark's results yet?
1. You cant get a cowbell to ring properly by hitting it with a sledgehammer. (overdriving)  ???
2. Finding a needle in a haystack is a tough way to find a working frequency pair. (building the coils with no thought to their resonant frequencies.)  :P
Because of number 2, for most the process is a hit and miss whether it works at all. For those whom have achieved the effect to any degree, it determines the efficiency of the device. The natural resonant frequencies of the control coils have to be harmonic with the frequencies of the circumference of the collector coil.
You CAN achieve results by accident (the basic process of inventing. Trial and error), but that is the expensive, time consuming, HARD way to do it.  ;)
Once you know resonance is involved, you DESIGN the unit to resonate on purpose. I can perform horribly inadequate arc welding with a quarter, a car battery, and a pair of jumper cables in a pinch, but does that mean I would purposefully build an arc welder that way?  :-\
The pioneers in this replication process have accomplished a great deal, and I in no manner disparage their work. However, there is a time for skull sweat, just as much as back sweat. If we do not understand the processes involved, we will never have anything more than toys, or industrial accidents, however the case may be.
If we understand the processes, then we can PUPOSEFULLY build our units, in a manner that they work every time, with but a little tweaking.
I have worked out but one plausible understanding. I am not saying it is the ONLY plausible explanation, but logically the pieces fit this puzzle.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
Esa Maunu
You must remember that a pulsed DC creates a static magnetic field, that does not travel along the circumference path of the toroid.
Esa
Quote from: pauldude000 on October 12, 2007, 12:58:45 PM
@esa
Paul Andrulis
