Appears to be overunity Cicuit
Started by Spewing, October 14, 2007, 08:00:23 PM
hartiberlin
No,
not 3 transformers.
You can use also just one 22 Volt coil as the primary and the 220 Volt coil
as the secondary.
I have to see, if I will find a better transformer, which has
a high wattage 240 to 6 Volts or so relationship.
This will probably then work much better,cause the 6 Volts coil
has a much lower resistance.
hartiberlin
P.S. I did not draw in the 2 neon bulbs in series, which are then hooked
across (parallel to) the drain and source.
These are important, when you use no cap parallel with the
coil, cause otherwise you will blow your MOSFET ,especially
at low frequencies !
A freewheel diode parallel to the input coil did not work... !
hartiberlin
P.S: I used 2 x P600 diodes.
As these 2 diodes only conduct into one direction,
only during conduction will be a pulse backinduced
into the primary !
This is very important and this way the drag back of a normal
transformer can be overcome ( think of  Lentz law violation...)
I am going to sleep now.
When  I get up in a few hours, I will work further
on this circuit and post pics and videos.
Regards. Stefan.
Spewing
ahh, your saying it matters which end you apply the pulse to..
Spewing
