Working Attraction Magnet Motor on Youtube!?
Started by ken_nyus, October 15, 2007, 10:08:47 PM
karl
Hi Karl,
Thanks for referring to that patent, I was not aware of that yet.  Now this is the second  suggestion for shielding magnetic fields.  The first one I learned is also a patent application using similar and other mixtures of powdered materials is here: http://www.rexresearch.com/wardle/wardle.htm  and was mentioned first on this forum last December:  http://www.overunity.com/index.php/topic,1771.msg20092.html#msg20092
I have not managed to test this shield, due to other commitments.  I like what they state (in fact the their patent application includes measurements with the shield).
rgds, Gyula
Gyula,
the wardle patent is the one which was worked out the empirical way. This is the real recipe.
The other patent proposed by me contains only the part of the silver in paramagnetics.
Coal Slag 40/60 (40-50?) is a substance used for abrassive (BLackblast ist the Tradename) with nearly the same composition than proposed in the patent (see website, google for blackblast).
Silverpowder is used in electronics or for painting and is easy to purchase. A fine powder (6my) is like a paste.
The tree other components a verry healthy (mybe it's better to eat them in small doses).
I think they mean magnesia (MgO), CaCO and ZnCO which is used for medical purposes.
My opinion is:
The substrate is basicly an fine structured insulator with a low content of Fe(x)O(y) with an diameter of app. 50 my.
when coated with Ag powder (the finer the better as proposed, mybe nanosilver).
We are creating microspheres with silvercoating! a micromirrorarray.
We should first test this:
Substrate with silver->test
addition of Mg, Zn, Ca ->test if there is an difference
I don`t have the materials but it looks easy to do this.
Costs: 25kg Coal Slag 40/50 10$
          10g
del_toro_es
In the hard-disk theare are two pieces of nu-metal, arrount the heat actuation device, that is a magnet shield.
m0thman
Quote from: del_toro_es on October 26, 2007, 04:15:48 PM
Again, I'm going to chuck in a few ideas - I'm sure its all been discussed before...? Did he not use part of a hard drive to mount the rotor on to?  Maybe the stator was made from parts of the hard drive.  I'm not sure what the casings are made of - they look like aluminium I guess, but is there any chance they have some magnetic shielding properties and that is part of what is going on here?  Another thing that occurred to me. I'm not sure what the rotor was made off, it looked like some sort of substantial ceramic thing.  I noticed that xpenzif was participating in threads that discussed flywheels and possibly magnetic shielding.  I say possibly because it was all quite beyond me.
Anyway, please ignore if its all too obvious.
karl
...teach me to walk softer...(Black Elk speaks...)
...teach me to turn smoother...(kaRLfunkel...)
Optical discs are not fully unterstood.
The thin layers on top are more powerful than you think.
Magnetic storage drives magneto-optical! layer proposes nonlinear characteristics related to different frequencies.
fresnel formula (optics: swinging photons & electrons, VHF, Light=)  & faster than light ->magnetic fieldlines due to stationary high speed orbitals which superimposed is called magnetic field(s) meets epsilons (stato magnetics 0Hz, not really defined->relative motion to eather).
With the same formula optical constants (f(Hz)) and statomagnetic or dynamomagnetic epsilons or mys unite to fulfill one point of view instead of two different systems (E & M 45 degrees....ooooohhhh). This means that the index of refraction on this optical layer is in directly relationship to the magnetic constants (permeability = continous bending of light + relative linear movement to aether >spiral motion, storing this information of motion in time without changing the molecules itself!!!!.
There is only one moveable energyquanta (electron or proton are two of a few resonating states) and an interaction between this orbiting quant(relative fast->small mass) and a restzing matrix called nucleus. Sum of energy is in every point of our universe the same: The whole universe is acting to each relative point in the room in an different composition of frequencies (Planets and greater influences) but in the same sum. In an other case an hole (black or white) is creating a new reality to fulfill the roompoints interwoven will to suck or blow materia.
Is the particle resting (better: circulating arround a relative resting mass of the fixed aether matrix, and concentrate this matrix to one smaller point)
Nonlinear optics is called "NEW PHYSICS" by BEARDEN. Is the keypart of understanding nonlineary and nonlogical interwoven interactions in the flow
and in the methamorphosis of an quanta (see saw seen). Past->Present<-Future........#There is only an changing Present which is called PUTURE#.
Light is pure aether energy flowed in in one relative resting room point.
But when we are moving we see an line of light which is seen by our eye due to suberimpositioin of the moments and the direction of our relative mass-movement (rotating earth).
Backwardengineered: The line of light (seen as...) ends in our eye. This is the interface between timeless aether (full spectra->photon, electron, magnetic particle, moveable quantas) and timeful resting matrix (heavy out of our resting view). The thinking and the inner light while creating ideas or dreaming is related to this timeless plane of sharing informational reactions (forced to react due to action which has happened). No instrument can really measure this finestructured energy but only the manifestation due to interaction of stored informative tendencies to influence the moving particles (electrons at light speed, magnetic particles at speed faster than light (creating it'S own mass in the center due to concentration of the in the vacuum crystalline arranged fluxating points), increasing the relative orbital radius arround their own sun (protons,neutrons,positrons, trontrons, strings and other insects) which is aan matrixed fixed, crystalline background which rests in the timeless and therefore not defineable frequency (already an definition).
The sea of energy (timeless plane) consists of every particle quanta in every time (time domain) and is therefore not measureable but present in every time and in every point of the room in every time.
This is also esoterical, because the timeless plane coresponds and interacts with the souls and therefore with the LOGOS itself.
Every wish is an samen in aether (no THE, this is not one thing it is everything at the same time) which starts to proove the possibilities to manifest on the
material plane (if you have an material wish...).
Every technical revolution should be done in absolute harmony with the inner spirit (white light). If there is an conflict with the masterplan (target of evolution) we feel cold and slightly or impressive confronted with the reaction. If we loose this sin, we are cought in the unreviewable situation of the reaction of the complete universe to this energydirecting room point (relative big brain), sucking to find a solution for EGO or ALL.
This is one key to find Free Energy: To know that it is still everywhere is the alpha on omega of thinking.
To give her a name is to relativize one aspect of her interwoven activities on all planes or creation.
To pray for foregiveness (because we want something for our ego and take it away frome live supporting energy lines) is half the way back to the roots of thinking and foregiving is guarranteed.
No sinner (technical or religious (backbringer)) is really remarkeable for his/her sharing of energy if the quanta is flowing to the point in our roomed universe where it is comming from due to a closed fieldline and due to the complete knowledge of all relative movements on all planes which results simply in an pulsating roompoint which represents the whole great work itself, because it is a mirror of the complete surrounding and including inner structure.
What we want is basicly eternity of a force between two defined roompoints or a sume thereoff (defined in the timeless and pointless manner).
The interaction was seen on the timeful plane e.g. as rotation of our drum which is mounted on an magneto-nonlinear-layer which is bending the room more or less on different levels of awareness, interfaced normally by an information sharing system, here interfaced by an rota information (turn at defined sequence) which interacts with the static information (change in time due to all times e.g. static NSNS information plus information dynamicly written in time due to pulsating and therefore rhythmic read and compare the write sequences, which are induced due to interlacing magnetic conductors (screws on lower level of array) which acts as concentrators to the stator magnets and therefore dynamicly changes information of the underlying optical layer more or less.
It's the principle of akasha plane to purely store, compare, sort and start reactions.
What we could find if we move this device one revolution arround is an information written on an nonlinear multifrequential EM interacting layer which forces all frequencys surrounding the disk to force this movement at a defined speed because of the time domain changing information written in relative circuilar angular speed from an system with an time active component relative to this with an pure faster than light character (static PMM'S placed arround an rotating energy dynamo).
Basic principle could be this:
I load an capacitor (one point or area of magneto-optical disc where a screw is placed between disc and fixed magnet) to high level faster than light information with magnetic fieldlines which travels faster than light (because it is not consuming energy from the magnet) and the following rotation of the disk acts to the stored information (changing of position due to gradient on the disc). The variable information is the time of rest in one configuration (one moment) and in our case a kind of arrayed time shifted (dekta T) ramped (screw, arrow, diorection) information. The sectret is to shift this signal and the momentary actuating signal as like if you hang an carrot before an rabbit to perpetual try to speed it up.
This principle was ofter explained by an endless magneto-accoustical cassett which is, after the first revolution, always rewriting it's own information by using a time and therefore space shifted read and writehead. rotational speed is then much much slower than informational speed on magnetic fieldline coupled system (and a plus due to overlightspeed of the magnetic quantas itself it is only pulsating and not moving relative to aether.
Koen1
Great Karl, but what does that have to do with the magnet motor this thread is about??
Has anyone actually managed to make a working replication yet?
I have found a number of replication videos but all of them show how an exact replication of the motor does NOT work;
all replicated versions slow to a full stop instead of actually rotating.
Who has actually made a working version, and what is the difference between their working version and the replications that do not work?
Anyone?
