0 Members and 188 Guests are viewing this topic.
Pirate88179
Bruce_TPU
Hey all,
I am at work, and when I get home, I may post some photos.
I want to retest the core.  When I laid the coil flat/horizontal, I tested the top left core and the compass turned to the core.  I tested the top right of the core and nothing!?
I then tested the bottom right and it spins the compass, but the bottom left does not.  I want to retest as soon as I get home, because it makes no sense to me at all.
I tested for volts and it read .002 and zero ma's.  Strange that it is magnatized at all, and the top north and south of the core seems to be opposite of the bottom north and south and seems to be diametrically magnetized.  Is that even possible?   ???   :o
Anyway, I will restest and then post photo's showing the compass.
Cheers all,
Bruce
Koen1
hmm... so a magnetic field is produced? Just a wild thought... does attaching a permanent magnet
to the magnetic core have any effect?
(probably not, but hey it seems an easy test ;))
and about that Tesla electric car, I seem to recall reading that he had the electric motor specially made for that car...
Since he was the guy who basically designed most of Westinghouse's generators and motors and invented AC generators
and motors, I think you should consider the possibility (or should I say probability) that Tesla designed the motor to work
as a motor/generator, with the box mainly used as a controller/regulator unit.
Now if we then consider the (alleged) connection between the Tesla switch schematics and the Brand switch, and the connection between
those and the Bedini switching circuitry, then it doesn't seem very farfetched to suppose that Teslas box with what clearly were various
germanium "diode" tubes and an adjustable inductance coupler (the two "rods" that could be moved in and out of the box, most likely
coils with cores) to control throughput current... But hey, that's just a thought ;)
jeanna
Quote from: Bruce_TPU on February 11, 2008, 03:32:29 PM
Hey all,
I tested for volts and it read .002 and zero ma's.  Strange that it is magnatized at all, and the top north and south of the core seems to be opposite of the bottom north and south and Bruce
Thank you so much for doing this test, Bruce
I tried to make pics last week but they are so small.
here is the set of pics for easier comparison with Bruce's:
http://www.overunity.com/index.php/topic,3500.1190.html
Notice that all the spikes are aligned east-west so not to be confounded by the earth's north.
(Later I decided that it is less confusing to put it upright, but you may not agree with that)
Notice I drew the compass readings to make it easier to see. The flash was in the way.
After Bruce posts his, I can repost the most relevant ones in bigger format, if that makes it easier to compare.
jeanna
PS Koen 1 It is not a bad idea to add a magnet just to see, but FOLKS, please do the compass check test first, you don't want any residual magnetism to be confusing your results.
Pirate88179
@ All:
I have already added a neo to my core and did not realize any noticeable changes.  I did this last week for yet another "what if" experiment.  I did not check with the compass while doing this as it seems obvious to me that it would effect the compass as it is a very strong magnet.
