0 Members and 169 Guests are viewing this topic.
jeanna
Something interesting happened.
I think the upshot must be that my tap water lacks electrolyte.
( yesterday I received a pm from an EE who suggested adding salt in increments. The results were too strange to know how to report. but now that the coil is out of the salt water and moist It looks the way I think it should)
Have a look:
Right now the #3 coil which is silk insulated cu and zn-galvanized fe, and a zn bolt with a secondary of about 200 winds, has some normal looking results.
The voltage across the wires 5,6 is about 359 mvdc as before, but the voltage across the
cu wire 5 and the zn bolt is 700mvdc. This looks right to me.
To add to that there are 300uamps between 5,6 and there are
1.5mA between the cu wire 5, and the zn bolt.
(this contrasts sharply with 150uamps and going down from the earlier reading)
I have a recycled modem speaker that makes a crakling sound when connected to the cu wire 5 at its + side and the zn bolt on its - side.
The compass snaps into position S pointing to the bottom of the bolt and N pointing to both  the bolt at the top and to the separate Fe wires 6, 10 at the top. It snaps sharply into place where before it swung into place. I would like to have a definitive way to measure this.
jeanna
Pirate88179
@ Jeanna:
Oh no!!! Do not use salt!!!!  I used very, very little and it shorted the entire works and all the reading went down near 0.  Not only that, it will eat up the metal eventually.  I soaked mine for several days in hot water, and all kinds of chemicals.  It is just now starting to act like a normal coil again. (This was my # 1 coil, single layer)
jeanna
Quote from: Pirate88179 on February 12, 2008, 12:37:48 AM
@ Jeanna:
Oh no!!! Do not use salt!!!! Bill
I remember, but I was getting such low readings and folks were thinking I had a short anyway, so, I just tried it.
It is fine. I think. The readings are continuing to decrease as it dries. It is no longer .7vdc. it is a strange little puppy.
But that compass is amazing. I mean it snaps into place. What a strange thing we have here. ;) ;)
jeanna
PS I am adding phone wire 1 strand as Joe recommended as the secondary to my #2 coil. I split and separated the six wires out today, then started wrapping. Lotsawork. :D
Localjoe
@jeanna
Im sorry they sell that stuff on a small spool w/o the grey sheith but i used network cable i think you have cat 3 there still should be interesitng, i wouldnt bother with a secondary tho untill you have the ammt of layers bruce and freezer have on theirs, im still not winding one as i need longer legs of wire for my primary
@Freezer
Your's looks great , cant wait to hear results
@bruce
Only conclusion im coming two with your compass readings is that theres two feilds and its getting confused try like 5 inches away from the bolt in all the same positions you did and tell me if theres any difference this should shed a little more light on it.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Bruce_TPU
@ Joe
Reading is the same, just slower for the compass to adjust.
I am convinced that there are at least two magnetic fields.  It is facinating.
Question:
How can a magnetic field be formed with no voltage or by using another magnet to magnetize the iron??   ???
That is a something for the lurkers to ponder, and myself as well.
Cheers,
Bruce
