0 Members and 81 Guests are viewing this topic.
Bruce_TPU
Evening all,
I have every thing tested and prepped for tomorrows evening experiment.  I will be using a 6.3 volt 150 ma bulb, incandescent, in a mini holder.  For the picture below I am using a regular 9 volt battery.  Tomorrow's experiment will use a rechargeable 9 volt that is even now, being recharged.
I have spaced my electrodes apart by 20 feet.  My Carbon rod is to the North, and galvanized spike is to the South.  A nice 1.23 volt reading between the two, at .12 ma's.  I have 8 awg wire going 19 feet from the positive back towards the spike.
The bulb will be placed in the jar, as seen.  The battery placed in a second jar, to protect them from the elements.  The jar will be slightly lifted up to allow air flow and cooling.
We will see how long it will burn...  ;)
Cheers,
Bruce
Pirate88179
@ Bruce:
My experiment today did not work out.  But, I think I know why.  First, I am sure now that I need to use a rechargeable bat. and will obtain one as soon as I am able to do so.  But, and think about this, I believe we are going to need a diode in the circuit.  My old electrodes were putting out:
1.7 vdc
6mA
The 9 volt is old and was showing 8.2 vdc.  I think what happened was the 8.2 volts lit up the bulb (12 vdc taillight bulb) for a while but why wouldn't the electrons from the 8.2 volts flow into the 1.7 volt earth battery?  I think they would, and did.  What I am saying is that we need a one-way valve (diode) in the circuit so this can't happen.  It seems to make sense to me that the 8.2 volts is going to flow to the 1.7 volt electrodes and not the other way around.  Does this make sense electronically?  I feel like the higher volts/current will flow toward the lesser volt/current.
I will repeat the experiment with a rechargeable bat. in the future but we need a diode, maybe not in the form of an led, but something to stop the flow in the "wrong" direction.
The tail light bulb was illuminated for about ten minutes.  9 volt bat. is "dead" now.
Bruce_TPU
Quote from: Pirate88179 on February 17, 2008, 07:06:39 PM
@ Bruce:
1.7 vdc
6mA
@ Bill
That is a great first experiment.  I will first try mine without a diode and can add one on the next go around.  I have a theory, but it is useless to say, I will know tomorrow.
At your youtube video, click the poster's name, who posted that awesome reply.  Then hit message.  It will send him a PM to his youtube account.   ;D  We need more info!
Good job!
Bruce
crash_uni8
well i have 5 "cells" in series and am getting 4 volts...but their isn't enough amps still... :-\
if i put the cells in parallel would i get more amps?
Pirate88179
@ Bruce:
Thanks for the youtube messaging info.  I copied and pasted your list of questions to "Uncleshorty" and hope to get a reply.  I again invited him to join us here.  I checked out some of his saved videos and he appears to have many of the same ones I do.  I think he would like it here.  I will let you know if/when I get a reply.
@crash_uni8:
Yes, I believe that if you wire them in parallel you will increase the mA. (milliamps)  4 volts is a good number for your series arrangement.  If you search back to about the first 5 pages of this topic, you will see where I posted a table on the galvanic materials and their numbers.  Carbon/graphite and magnesium are about the farthest apart on that table so you will get the most volts/mA.  You will also be able to see some other more easily obtained materials and figure out which are best for you to use.  If you can't find it, let me know and I will search for it and post again.
