0 Members and 184 Guests are viewing this topic.
jeanna
Hi MW383,
QuoteAs far as experimenting, I have found best magnetic fields when multiple coil layers are all wired in parallel. This is probably due in most part to the resistance being less but I will let more qualified electrical wizards comment on this. Wiring in series (unidirectional) was less field strength, wiring in series (bidirectional) was last place in field strength.
Your tests may have shown the exact right order of these things... however, the magnetic effect might be moving at the khz to Mhz levels and in that case, I think you could miss it, so please do not rule that one out.
jeanna
MW383
Jeanna,
This system will need a strong magnetic field not only to induce current into a secondary coil, but to also generate an earth response of electrical nature (the vertical component of the natural earth system) The primary coil I am building will eventually do this. In fact I will build and test primaries until I succeed. I am certain the first one will however..... I really could care less about the voltage as it will always be low in this electro-chemistry. The game will be amperage and this is a game I know I can win through construction. Construction that is hinted at (but not specifically described) in the NS patent.
As far as frequency goes, this will be a key factor in making the battery work well when in earth. Stubblefield was working in the low audio range. To me this means 20Hz through say several KHz. Obviously slower frequencies can be handled by various mechanical or magnetic make/break type devices. faster frequencies will require something solid state / electronic. Because of varied ground characteristics for each unique battery location (ranging from surface through depths into the thousands of feet), the frequency will be unique. Therefore one would plant the battery, vary frequency until the sweet spot is identified. There may be further adjustments necessary due to system gain of strength over time, and climatic variances.
Here is a picture of what I was talking about in prior posts.....
-------------------------------------------------------------- ground
                                       l
---------------->--------------------->---------------------> natural magnetic field (2.5MHz?)
                                       l
                                       l
                                       l
                             natural electical
                             component at right
                             angle to natural
                             magnetic field
There are other frequency things to consider and I suspect these were noted by Stubblefield at the very end of his life when he was living in the shack. Rest assured I am on the case here too. Actually I am further with this subject than Stubblefield's battery right now.... but a new thread should be started for this topic. I may do this after I am successful with the battery project.
So make a good magnetic field and pulse it just right and allow the earth to do the rest because as stated previously, it will react in order to seek equilibrium.
Happy experimenting !!!
MW383
Other things to consider:
           air based energies
                     l
                     l
                     l
                     l
          (cancellation zone) near or at ground level.
                     l
                     l
                     l
                     l
          ground based energies
Stubblefield was reported to have buried his earth batteries underneath old oak trees. This is interesting to me because a tree lives in both air energy and ground energy environments. I will have to think further on this in regards to effects on an earth battery..... There are some other significant aspects here that I am currently researching.
Pirate88179
Stubblefield also demonstrated his devices in Washington, DC in the Potomac River which has no trees so it still works without them.  There is a photo of that somewhere either here, or on my topic.  Actually, that was the first ship to shore communication by voice in World history. (He was demonstrating his telephone system which really was a cell phone system)
MW383
In a bundled iron core, is it ok to use paint as a method of dielectric insulation of the individual strands? I read somewhere about nailpolish but this seems like a lot of effort as there will be many strands in my core....
