0 Members and 23 Guests are viewing this topic.
BRAHMA
Quote from: akashh on November 27, 2007, 08:15:29 PM
@all: two ideas
1) From wikipedia: Granite is a normal, geological, source of radiation in the natural environment. Granite contains around 10 to 20 parts per million of uranium. By contrast, more mafic rocks such as tonalite, gabbro or diorite have 1 to 5 ppm uranium, and limestones and sedimentary rocks usually have equally low amounts.
What about trying to stick a lump of granite at the core of our coil?
Just following along with this thread and the thread about power generated from a pyramid, I suddenly rememberd that in the actual great pyramid, there are 5 huge slabs of granite above the kings chamber.  Maybe granite is some sort of magnifier.
just a thought
akashh
@brahma: That's an interesting idea.  I am also following the pyramid thread but was not aware of the granite in the egyptian ones.  I guess one could easily enough wind a coil around a lump of granite and see whether it does anything... :-)
@all... was just reading up on basic electronics and physics.  When I came to the section on magnets it said vary clearly that the earth's magnetic field is not understood yet.   It then talked about natural magnetism vs electromagetism.  In electromagets there's always an electric field and magnetic field present.  One does not exist without the other.  Now why does that not apply to normal magnets?  Maybe it does but the field is closed loop, and we need to find a way to 'break' that?
Another though relates to the tpu.  I was thinking about reversible effects.  I stuck an LED under a bright light and measured voltage!  So I'm wondering whether running the TPU under bright sunlight will show a different run time vs in a dark box.
Pirate88179
http://sci-toys.com/scitoys/scitoys/radio/xtal.html
The above link is to a coil calculator that I found.  You plug in the wire dia, etc. and it tells you what you the frequency the coil will be, etc.  This appears like it might come in handy.
hansvonlieven
Good find Bill,
Sorry for not posting much at the moment, there are a couple of reasons for it. I am having to look after the animals of a relative that is in hospital (she is getting much better) and I am trying to find out if the Helmholtz statement about exceptions to conservation of energy has validity. This much you know.
My reasoning is that if it is real there must be evidence of it in other areas, such as chemistry for instance, since I cannot imagine the principles to be confined to electricity and radiation etc. only. If it is real it MUST apply across the board.
At the moment I am looking at Dr. Griffin's and Dave's work and some interesting things are starting to surface. I will write it up as soon as I have a bit more than I have at present.
So please bear with me, I am still at it.
Hans von Lieven
yaz
@all
What do you think about this? An earth power module.
Last schematic on the page.
Quote from the page.
"Hey another cool thing I found is that if you earth both the earth of the circuit to ground and the other end of the antenna to a separate ground, you increase the power dramatically, compared to using a normal antenna and coil."
http://www.angelfire.com/ak5/energy21/ambientpower.htm
