0 Members and 194 Guests are viewing this topic.
Pirate88179
Conrad:
No, I have seen no evidence of any breakdown of my materials and it it going for over 2 years now.  The electrolyte, I believe, it a combination of moisture and the surrounding earth.  If it was just water, then my set-up should work the best when it is really wet outside, but it does not.  It works the best when it has not rained for weeks and the ground is dry.
Stubblefield always said that his devices would last in the ground without any breakdown of the materials.
As far as stray 60hz currents running my electrodes, I do not think so.  First, the frequency of my electrodes is much much lower than that.  Also, Stubblefield's old farm location is about 2 hours west of me.  Some claim that his energy was coming from the grid via leakage too but, there was no grid in his area at that time.
I am not sure how to prove beyond a doubt that my electrodes are not getting something from the grid, I just do not believe they are.  But, we do pump a lot of energy into ground systems all over the earth and there are a lot of lightning strikes all over the planet every second so, it may be very hard to determine for sure.  I just know I am not getting anything like 60hz which is our standard over here.
Mk1
@all
I have been wondering why not just use a reed switch on the bolt , or turn the coil into a relay switch ?
Mark
IotaYodi
Quoteanything that you have 0 input and get >0 output has to be ou in its most fundamental form.
The way I look at is 2 ways. The way the device measures it and the unknown or external input like the Aether. Ive seen it stated that current is really produced by the Aether through electrical devices,transformers,generators etc. If thats the case then the device as a whole is just a conduit to direct the Aether in the proper manner. If you have a universe full of Aether then it would seem to outweigh any other input. If the Aether is responsible for the electromagnetic spectrum alone, then I see the Aether as the main power source or input. We have put mathematics of positives or negatives from certain reference points, but the reference point has never been the Aether as far as I know. You can use standard reference points and suspect measuring devices and call it Ou, but in reality is it?  If we are indeed extracting energy from the Universe,its just microscopic from its reference point. An example of that would be Sweets Vta using a barium magnet. Leaving this thing on they heard a whirlwind that seemed to get louder. It takes force to make that sound. The Vta created a Vortex into the aether by way of the tuned barium magnet. Scary stuff!
Anyway thats why I dont think of it as over unity. What we call it is unimportant. We just need to get it!
What I know I know!
Its what I don't know that's a problem!
Pirate88179
IotaYodi:
Agreed.  It might just be that this is tapping into an unknown or undefined energy source not unlike wind or solar power would have been before they were understood.
But, you are correct, whatever it is, we need to get it.
jeanna
Quote from: Mk1 on May 22, 2010, 04:14:21 PM
@all
Mark
Do you mean to put the reed switch in the right spot so it makes and breaks as it wants?
I think it would need to get started. In laser's first rotor remember it took about an hour to get up to its full speed.
I am seeing this kind of thing with my minimally powered jt in the ground.
They can be off, but if I charge the cap (which is parallel to the leads) sometimes they will continue for days and days (rather than 10 seconds to run the cap down) but if I never did that little charging the circuit would never start.
(This trick only works sometime).
Can you think of a way to start it?
jeanna
