0 Members and 131 Guests are viewing this topic.
electricme
@ Bill,
Nice find there with the above telluric field meter circuit.
I think with a little tweaking we could get a LED to glow in time as any telluric field passes (or pulses) by the short antenna.
To do this the mA meter could be replaced with a LED, a T-pot both being placed in parallel across where the capacitor is, this and LED, representing the "load" must be matched to the output that the circuit sees when the meter is in circuit.
In other words, what the circuit "sees" as its load with the meter.
If we make up several of these circuits to drive several LEDS, then we should be able to actually see the telluric wave as it flows by the antennas.
I must take a more in depth look at it at the www address I see there.
@ Jeanna,
That is a nice looking stubblefield coil there, try and keep those winds straight and in line, if they are not, the magnetic fields will be widened where the wires are not wound so close together, or magnetic fields forced tighter if the wires are wound tighter or closer together, we need an even distance between them.
@all
I eventually got my higher satellite speed back, before I couldn't even open this page let alone answer my PMs which I have done by now.
To those who sent me PMs, all I can say is sorry, my ISP knobbled my connection so low (below dial up speeds, try 206 bytes) many web sites just refused to open for me, Overunity being one of them, I hope you understand.
jim
kukulcangod
MR. Electric
Your work is remarkable I know you won't quit at it, what you have unearthed is of extreme importance, best proof that this batteries really exhisted and in such fashion, eliminating as of now the possibility of this thing being just an attention getter for egomaniacs, hoaxers. I share the frustration of bad signals and limited time at a great great distance, you must continue, pure of heart as I feel you are, for the truth will hit hard in the face those trying to just have a sick satisfaction at misleading us.
In my modest research at the pyramids in Mexico, I discovered that certain people are more or less sensitive to this tellurics energies, which I also think is "bioenergy" , James Cameron I'm sure based his movie "Avatar" on this idea, to the Mayan it was a reality, let's start with my own experience to better illustrate the point, (talking about attention getters!) I was about 5 years of age when I touched "la piedra de el negro" or "The Hueyepan Head" out of curiosity in the middle of the museo in the city of "Catemaco" well known for thousands of years of shamanic tradition, people came over and over again to get their fingers wet in the cavity at the top of the african like features huge rock head, which used to belong to a shaman , so I extended my arm and touched it, just to get a tremendous jolt of energy thatn numbed my arm making absolutely cold!! it felt as if hitting a wall with my arm extended after running towards it, I went hysterical and grandman though I was bitten by a bug... it would take about 30 years for me to find out more about the subject via a small book publicized by a spaniard researcher, The rock was said to be oriented in a certain way for it to get "charge" with the curative energies and properties the shaman created it for, other than that it wouldn't work, remember the mayan were also experts at curing with water etc, The consequence of such jolt was getting this vivid dreams and perceptions , now remember in certain interpretations one of our biggest cities is named Teothihucan" "city where men become gods" I found a way to cure myself with such energy and water a while ago, they knew about this , and they accumulated this energy with the pyramids also aligned with the earth poles , incredibly it is not very well know that such pyramids and "la piedra de el negro" are made of piezoelectric materials, folks this is what we are taping into, but remember that the pyramids are built big for a reason, to better acummulate this energies, and don't forget the poles are shifted ever since. I hope this illustrates the point, enjoy.
Cheers
electricme
@ KUK
Thankyou, sometimes I almost giveup but am able to find the energy to keep going.
Your personal story is remarkable to say the least, I decided to findout more about the Hueyepon Head, eventually I fell down a rabbit hole and landed up here at http://www.free-energy-info.co.uk/Chapter3.pdf if you are able to read to the end, you will discover many free energy devices, all because you told all of us readers about what happened to you. ;)
The contents of the above web pdf is worth burning to a CD.
jim
electricme
@ Jeanna,
Exploded resistor?  :D
Quote from: jeanna on June 19, 2010, 05:15:20 PM
I finished row 7 on my #14 NS coil! yeay!
Yesterday I got a new unexploded 1 ohm resistor and I can now read the amps available from this coil.
jeanna
Ha ha, so you are getting a little energy flowing through a 1/8th watt resistor, good.
Try changing it for a 1/2watter or 2 watter, as each one burns out move onto a higher wattage resistor, you are on the right track.
Another way to measure the energy is to see if you can measure the degreese in temperature on the resistor, put a temp probe on the resistor, set the DMM to degreese and then turn on the DMM, then turn on the power flowing through the resistor, if the DMM starts to climb in temp, then it is showing energy is flowing across the resistor.
Got your 7th row completed on your stubblefield coil, lets hope it will perform like the original stubblefield coil
Good work.
jim
jeanna
Hi Jim,
I am glad you can post again!
The resistor was one of those enormo ceramic jobs. I am thinking it got wet then rusted, because for a while it continued to work if I jiggled the wire, but finally it stopped.
I threw it away and bought a pkg of 2, 1 ohm resistors...the same big square ceramic ones. I am trying to keep it dry especially when I am spraying water onto my galvanic batteries.
thank you,
jeanna
