0 Members and 88 Guests are viewing this topic.
Pirate88179
http://www.overunity.com/index.php/topic,3828.0/topicseen.html
@ Jeanna:
Above should be a link to it.  The way I find the topics is by selecting the "Home" button near the top left of the page.  Scroll down and you can see like the last 50 or so topics that have been posted in. It constantly changes.  Mostly, I just hit the "show replies" selection under my picture to check the topics I am interested in.  Good luck with your experiments.  How long has your light been on now???  These little things are impressive are they not?
jeanna
Quote from: Pirate88179 on December 30, 2007, 01:22:02 AM
@ Jeanna:
Thanks.
I last charged it at 5:53 german time and when I saw tha light was still bright it was I think 6: 13 so it was bright for about 20 minutes on a 30 second charge. I am very impressed.
Mostly I am impressed with the fact the cap can be charged and the light can shine at the same time. This means there is no need for fancy switching. Fancy switching is fine, but I don't want to be dependent on it. I have 18 or so LED lights that I use all the time. They are in every room. I use rechargeable AAA batteries which last anywhere from 1 week th one MONTH on a recharge. The difference between the week and the month light is merely the difference between a 33 ohm and a 47 ohm resistor.
I love these lights. You can't read by them but soon...
Thanks
jeanna
akashh
Hi All - I found a link with some guy's theory that is fantastic: http://www.geocities.com/terella1/
Basically he took Faraday's paradox and thought about it - there are some strange unexplainable things that happen with a Faraday disc.  He then does a couple of other experiments and concludes from that something interesting: A magnetic field CANNOT BE ROTATED ON ITS POLAR AXIS.
Which means that although the earth is rotating, the magnetic field is not!  Therefore, telluric currents are nothing other than the current induced by the earth rotating around it's stationary polar magnetic axis!!  This bring a whole new light to the phenomena and may help us in understanding how to use it.  I'm gonna spend some serious time thinking about it.
Bruce_TPU
Quote from: akashh on December 30, 2007, 05:49:17 AM
@ akashh
Thank you for posting that link.  I for one, find it of utmost importance.  It also confirms what I have been thinking about Stubblefield.  I believe he figured this out, so long ago.  I am also convinced that this is the only possible explanation for why his device worked.  He only tapped it through induction, and the electricity being generated in the coils were a result of a magnetic field moving over his coil.  This would allow him to tap that, through induction.
What we have been doing with the earth battery is tap the electrical current, inducted into the rotating Earth, in a moving magnetic field.  We will see, but it makes absolute and perfect sense.  And this is the way I will experiment, once I arrive back home.
The following segment is the part that speaks to me:
"For all those scientist, who searched for reasons of telluric currents and explanations of geodynamo process that is creating Earth's magnetic field, please take this fact in consideration. It is of utmost importance. Feel free to forget all theories and hypothesis you know. Just perform these five simple experiments and conclude by your own mind and reason.
To me conclusive experiment is more than any even so beautiful theory. Facts are facts.
"We do leave in sea of energy. Free energy. For if we would be able to construct a simple coil in which only one half would be sensitive to induction and other half noninductive, we could gain almost limitless quantities of electrical energy just from fact that we rotate and move in Earth's magnetic field.
Please do not confuse the rotation of magnetic poles around rotational axis of Earth. Earth's magnetic poles relation to any point on the globe does not change with the rotation of the planet. Position of poles rotate of course. But the magnetic field does not."
New Year's Cheers,
Bruce
georgemay
Akashh,
Thanks for the link.  I did following experiment:
Put some iron filings on piece of paper,  put magnet under the paper rotated with fingers while holding the paper, rotated with drill.  The magnet filings didn't move!
It proves that magnetic field cannot be rotated on its polar axis.
Next project:  Stubblefield coil.  Last Friday I got iron and bare copper wire from McMaster.  All I need is to build some support  for spools.  I will use my lathe to do windings.
George
