0 Members and 89 Guests are viewing this topic.
Pirate88179
@ Bruce and Joe:
I don't disagree with your points, they are good ones.  I just want to get the power up to something anyone could view as useful, and then work on consolidating and compacting it.  Kind of like computers, if they tried to build ENIAC (which took up a large room) to fit on a desktop as a design parameter, we would still be waiting for them to build it. I don't have any extra $$ at this time so it may be a moot point.
I had a dream last night that I took my two magnesium blocks and drilled two holes  in each block such that my zinc spikes could go through the holes and make a frame. (Kind of like what Freezer was doing)  then, I was going to wrap the zinc with bare copper wire, which would give me 4 wire ends , or two, depending if I jumped the wire over to the other zinc spike or not.  I am not sure what do do with these ends unless I use them (tied together) as an attachment lead?  My thoughts are that both the mag. blocks and the zinc are on the extreme minus end of the scale and possibly the coil arrangement with the copper wire (with zinc cores) might "gather" more mA.  You guys think this is worth a try?
Pirate88179
Here is yet another really crude drawing to hopefully explain what I was trying to describe in my last post.  I have the stuff here to try this today if I want to.  It won't cost anything but time.
     ps I did not get Freezer and Artic Knight confused again (Ha ha)  I borrowed Freezer's plates cell idea and used
              Artic Knight's wire wrapping coil test idea as well.
jeanna
Quote from: Pirate88179 on January 05, 2008, 01:01:59 PM
DO IT
jeanna
Bruce_TPU
@ Bill
That looks like a great idea to try.  I look forward to hearing the results.
While waiting on my magnesium and carbon rod, I tried several experiments today.
I tried using a carpenters pencil, sharpened at both ends as one electrode, and a zinc nail for my other electrode.  The reading was 750 mv.  No ma.  Zero!
I then tried a mini Stubblefield type coil that I wound.  I saw 1.2 volts on the primary, which was five layers of thirty wraps each, bifilar 20 awg magnet and uninsulated steel wire, around three zinc nails.  Secondary was of 20 awg magnet wire.  I am thinking now I should maybe overwrap that with more steel wire.
It only registered voltage, as it went under ground.  But, still, NO ma.   ::)  And that was sad.
So, I think there is something to the bifilar copper and steel, but still missing amperage.  I hope that the carbon 1/2" rod and magnesium blocks will provide better.
2008 Cheers,
Bruce
Pirate88179
@ Bruce:
That's very interesting.  Were you alinged on a global orientation? Or just picked a few spots?  I would have thought you would have seen at least some registration of mA.  But, interesting that you achieved a pretty good volt reading with the primary.  So, in the really terrible sketch of my latest crazy idea, where would you connect the wires from the windings?  I guess, all bets are off here anyway so maybe a few guesses and several different configurations are in order.  The way I see it, I will have two zinc rods wrapped and I can either join them at one end by jumping over to the next rod, or, keep them isolated.  If isolated, I will then have 4 wire ends to do what with?  I can make it like series and just continue on down the second zinc spike while winding but then, I will have 2 wire ends.  Do I tie them together?  Do I "ground" one to a magnisium end block?  Should I tie them together (like in the picture) and use them for the connection lead?  I guess this is what experiments are for.  Any advice you might have would be appreciated.  Thanks.  P.S.  Where is a good source for copper wire?  the home stores around here don't carry it unless I buy romex and strip the ground wire out of it.  Or, should I use steel wire?  I know, too many questions and not enough answers.  Thanks.
