0 Members and 141 Guests are viewing this topic.
jeanna
Thank you Bill,
I'm gonna drop back and punt. I want to describe what I see. Maybe if we all do that we can pass around ideas. ?
I See 4 coils like chokes. 3 are one size and 1 is shorter. I can not see the ground but it appears that they are stuck in the ground. On one of them the wire extends to the top of the black box and I see another shorter coil at this top spot but I can't see if it is from a separate wire but it looks to me like the end of one of them. On the top does one of these wires become that antenna looking thing?
On the other side of the black thing, next to his son, are 4  straight poles. Again probably but not shown to be stuck in the ground. 3 look similar in that they have a globe on the top above the "beer can" and one is shorter and has only a hemisphere on its top part.
I see one wire from each of these and on the 3 taller ones with globe tops, I see the wire attached to the very top and circling around to attach again at the bottom of the globe. (I see this mostly in front of the child's arm.) On the shorter one the wire is just attached at the bottom of the upper hemisphere. In all cases, I see them no longer touching the pole and appearing to go down. Maybe they also touch or go into the ground?
What else do you see? There sure are a lot of wires and things
jeanna
Artic_Knight
altho i have not proven it yet and it may already be known knowledge, i believe i have a way of turning a multi coil assembly into nothing more than a capacitor that is unlimited in its capacitence! its a theory at this time however.
i think that perhaps what we should be exploring as far as coils are concerned is iron wire coils.  thats my personal opinion. as far as your device, it looks fine, please test it and see what happens! but in the spirit of testing if it fails or if you get a wild hair, alter it while your there and see what else you can do!
on all of my experiments i intend to do one thing and eventually mix it up and try many things, lets take the step up transformer or makeshift jule thief for instance, i took a nail and wrapped 2 coils around it, tried them in different configs with the nail then tried them as air coils nothing worked, out of bordom i left one coil on it and stabbed the nail into the ground, with the coil dangling above the ground i started to get something, i then tried adding the other end of the coil to ground ect and found that a coil plainly wrapped around a form of iron makes a nice ac current! all from frustration because one experiment didnt work LOL.
i say dig a hole and bury it, lets see what it will do, after your done, modify it and see if you can figure something out that works!  once we get enough working devices perhaps we can find what is actually happening and optimize one device to work better :)
the spirit of inventing and experimenting is to modify and change something till we get results, then go back to the desk and devise more!
Artic_Knight
a comment about hanz ceramic pole items.  it looks to me like its rebar with a material that acts as a capacitor and a coil to tap the usable current from the capacitor.
the pole in the center is positive tapping from earth, like the large cap i have here, the outer rim is resistive and the coil takes the radiative energy and turns it to something amplified and more usable.  for instance the old beer bottle capacitor.  if you research tesla coils you will see some home made caps out of glass beer bottles aluminum foil and an electrode inside the bottle.  same basic idea slightly different results.
however remember we are dealing with volts and amps multiply the two and you get watts, there is no electrical device known at this time to take a watt and increase it, so if hes making this current more usable hes simply upping the voltage and lowering the amps respectively.
jeanna
Quote from: Artic_Knight on January 08, 2008, 10:20:15 PM
Which cap is that?  Are you calling the nail in the ground the cap? (Or did I miss a page?)
Outer rim?
Yes, I have made a couple of this type of cap. but I am missing the part where the coiled wire comes in.
And I remember the time I took a cap and juiced it then connected it to a resistor and a light. Without the resistor there would have been NO amps and no light, but with the resistance the amps happened. Well the light happened. I started out with just volts no amps then through the resistor I got a light.  It is this that makes me not worry about not getting amps in my earth battery. If I can just get enough voltage into a capacitor I can rig it up to get amps.
I think these coils are very interesting because they may be able to bring down some voltage in a less than lightning size quantity.
Thanks Arctic Knight. You go very fast and I have a time keeping up with you, and I think you have good ideas. Please explain them more fully.
Thank you.
jeanna
Bruce_TPU
Hey Guys,
I received my Carbon rod via UPS today!  It is a hollow rod.  This should give me more surface area, if that matters.  I will try it tomorrow and hope for some ma's.   ;)
I am still waiting on the magnesium fire starters.
I want my micro tpu ground powered by the end of this weekend.
@ Freeze
I saw the picture of your cells, and as close as they are to one another, they are capacitors with the earth as a dialectic, no?  This is how my copper/ zinc couples are set up, but the plates may be the way to go.
I saw four plates per cell, is this correct?  Have you tested with only two plates, or six plates, to see if it matters?
What metal type are your plates made out of??
@ Bill
Have you tried your coil yet?
Cheers,
Bruce
