0 Members and 176 Guests are viewing this topic.
Bruce_TPU
Good morning y'all.
Sorry for my absence, I have been very busy, working on the OCAL Magnet Motor.  But, because of a parts snafu, I have several days free, for other things, while I await the proper sized rotor.
@ Bill
I finally did get in my two magnesium blocks, but have had no time to test, and when I did, it has been raining.
@ Freezer, Mr. Spates and All
I read through the entire .PDF Freezer posted.
I think that it has a wonderful place to start and experiment, using a coil as a ground capacitor. I would suggest pages 12 through 14 and page 21. This is fairly easy to wind and has full instructions.  If it works as said, then that is it.
I have reposted the .PDF for download below, for convenience.
Cheers all,
Bruce
Pirate88179
@ Bruce:
Thanks for reposting Freezer's link.  I guess I missed it the first time around.  I downloaded it and it looks interesting if it is true.  An order of magnitude improvement on my results appears possible with this set up.  I suppose the north/south alignment is not required with this type of coil as it seems to be a self-contained unit in and of itself. 80 volts?  With 10 of them 800 volts?  I will re-read it but I don't recall seeing any amp readings.  If there are any there, this could operate a lot of things.  This is great, thanks Freezer and Bruce.
Freezer
I'm pretty sure the article meant 0.89 volts, not 89 volts.  I think the capacitor idea is a good idea to try as well.  I read another story that said this guy built a wooden box, with layers of steel wool, sheets of foam, and two copper rods.  He claims it put out 100's of volts, and thinks it works similar to a layden jar.
Here's some more related links.
http://www.geocities.com/tasosmit2001/electricity.htm
http://www.nap.edu/openbook.php?isbn=0309036801&page=232
http://www.roymech.co.uk/Related/Electrics/electrostatics.html
http://en.wikipedia.org/wiki/Water-activated_battery
http://www.thelenchannel.com/1galv.php
http://www.smeter.net/grounds/soilskin.php
Carbon sticks
http://www.unitednuclear.com/chem.htm
hansvonlieven
@ Bill,
In the Stubblefield patent it shows the coil as wound in a conventional manner, except it uses one iron wire and one copper wire side by side instead of the usual single wire. This actually smacks very much of Tesla, since it was Tesla who was so interested in bi-filar arrangements. I think Stubblefield worked much more under Tesla's influence than is commonly believed. I think the whole Stubblefield thing were early experiments in "Radiant Energy" developed by the pair of them under the direction of Tesla.
Hans von Lieven
jeanna
It is snowing today. Made me think of something.
Joe, do you still have your spike set up in the tree? In Vermont there is an expression called 'snow-eating fog' well not an expression, a kind of foggy day. It happens around now to mid Feb. and when it happens the maples give forth an abundance of their sweet juice. I would think that during the snow eating fog you would get some voltage. Just wondering. If you are still set up to check it when it happens.
jeanna
