The ~~~~"RACK"~~~~~
Started by innovation_station, October 21, 2007, 01:13:53 PM
innovation_station
a posible solution
for offset
or phase what you want to call it
wind 3 trigger winds for the input of the next gen  ;D   see do you get what i mean or do you want it out right??
hell  here it is  we have 3 coils of say 5-10 turns to detect when to fire the next coil or sig genny!!!!!!     thease coils are located @ 3 diffrent places around the coil  but you know what we arnt there yet  ;)  but soon!!!
ist
so when you first start it then what it is a cat chaseing its tale  it will only take a pluse or 2 to start  we must bring our siginal out of the center of the ring to close the loop after first or second fire  and recycle recycle recycle recycle  how???  with our mic of course  or is that our balum? hummmm
rMuD
I meant DC Offset, only important if your doing DC Coupling on the output stage for having a simular Ground, or if you want to offset a signal to more positive or negative when combining
Quote from: innovation_station on October 26, 2007, 05:57:52 PM
a posible solution
for offset
ist
innovation_station
so you speak of the power supply
for the gennys ??
as in a split rail im not right up on all the electronic terms
like 5- gg 5+  i was going to use the ground as sheilding for my siginal carrying wires
i did find a power supply i hope to use for the unit but we will see
ist
the outputs of this supply are
+3.3
+3.3
+12
+5
+5
gnd
gnd
gnd
+22
-5
i was gonna try the +5v gnd -5v  to power my generators if no luck i will keep looking i have quite a pile of stuff kicking around this place  kinda of wish i i never threw out those 30 sat recievers i had for forever  but you always need it after the fact  :)
innovation_station
a  question for all the smart guys here
lets look at cat 5  ethenet cable
if you notice they are twisted in pairs then sheilded  when i was installing wireless internet i was told that there were less losses in siginal when the wires were paired and twisted
so my question is this can i use a twisted pair of cat 5 1 wire for siginal and the other as sheilding 1?!?!?!?!  this is for inside of my box only  all out side connections are made with coax input output test and read points there 19 external connections on my box 13 output points and 6 input
ist
i dont see how i could go wrong useing cat 5 inside my box  the more sheilding the btter  ;)
oops is that some kinda of secreat hummmm!!!! well for results in the force feeding part yes it is when useing ss outside of the ring with a tube amp  yes this is not the right path  :(  not the way sm wants  :( it makes  me sad that i have to do it this way but here we are but just cuz i want to keep it real!!! i will do tubes too  as i get more money to play with when i am compleatly finished this project i will totaly understand each and every aspact of this unit  :) and that makes me happy then i will teach it to those that want to learn it to better them selvs and save a few bucks
but those of you that want to do it the right way like sm would like please use tubes  the path will be easy for your scucess  ;)
why do you think we need to use tubes!?!?!?!?!?!
mflynn44
We're not likely to ever re-engineer the T.P.U. without first starting with tubes as SM suggested.
I think you won't see anything useful without floating grounds. Common grounds kill O.U.
