Rodin Theory & Coils
Started by acerzw, October 28, 2007, 05:26:57 PM
acerzw
@All, Welcome... Builders, Researchers and Theorists alike...  :)
I was researching the Steven Mark 'Toroidal Power Unit' and trying to help in the replication effort, I have now decided to work on Marko Rodin's Theory with the ideal of building a working Rodin Toroidal Power Generation Unit (RTPU)... based on a Rodin Coil... (thanks to wattsup for suggesting this thread, and for c0mstar for putting me onto Rodin's work.)
Rodin's theory is steeped in new age thinking and his claims are extraordinary, but if you put in the time to see past that you will see the undeniable truth of his new mathematics, which does show patterns in the basic theory of maths that have been missed until now, and does encompass all of existence... It will blow your mind...
so check out his site with an open mind:
http://www.rodinmath.com/
and his videos on you tube, here:
http://youtube.com/user/MarkoRodin
I will primarily work on Rodin Theory as I am really an analytical person and not a builder, though I will build if I really need to...
There is one thing I must state very clearly at the beginning of this thread:
Please approach what is written here with an open mind and before you post, please take time to understand the ideas on Marko Rodin's website. If you don't like his ideas or theories then you are probably not in the right place...
This thread is intended to be positive! Help keep it so!
A couple of simple requests to posters...
If you have more to add to a point you have already made, I would ask you to amend your original post if it does not alter its context within the thread (and thus make a later poster look like an idiot!) It saves space and makes the information content of the thread higher per post.. I adopt this practice so you may find if I have posted an answer to you that it might grow in time...  ;)
If you reference another posters ideas or information for the first time in this thread, please credit them by name and highlight their name in blue, credit where credit is due, also others can then research the original source posts.
Let the research and fun begin... :) and to give you a helping-hand/start please find below, the suggested build parameters for a basic coil (to help keep some uniformity to our endeavors, though do experiment outside of them) some useful links and a thread index  ;)
oh, and please PM me if you wish me to add/change anything below...
Suggested coil build parameters - updated 9 Nov 2007
work in progress... (thanks to Motorcoach1 for suggesting this section)
Absolutely no materials with high dialectric properties, to avoid magnetic saturation and field limitation
See JNaudin links for an idea, but don't use ferrite...
For practical Rodin coil winding advice, from a master, I recommend that you view Rosphere's posts from page 3 onwards! To see Rosphere's completed coil, a thing of beauty, look here:
http://www.overunity.com/index.php/topic,3529.msg58530.html#msg58530
  • circumference - suggestion only, a portable size 6 inch
  • air core material - ideally ceramic or other low diaelectric material, to avoid magnetic saturation
  • wire type - your choice, but must be (flat if pos.) single strand/solid copper (see note below*)
  • winding turns - multiple of 9, vortex (oscillations) centre number...
  • winding style - see Russel P. Blakes paper on Rodin's site, or examine JNaudin coil (see link below)
  • wire length - determined by number of winds, not critical at this stage
  • central energy collection rod - again not ferrite... copper?
  • waveform - sine, pure as possible... natures way...
* The fields created within multiple strand wire will create an uneven 'dirty' field, due to the fields of the individual strands interacting, which will then make the whole coil field 'dirty'. It will rotate etc, but I suspect the more interesting effects will not be present, the exact field topology is critical. Sloppy loose windings are also a big no, again they will distort the shape of the field.
Links to Rodin coil/toroid work elsewhere... - updated 30 Oct 2007
Links to work that support Rodin's... - updated 29 Oct 2007
Index of Important Posts - updated 9 Nov 2007
This will be updated from time to time, showing the last update of each important post... (thanks to Motorcoach1 for the idea) Join the effort, get your work listed here... credit where credit is due :) but note if a post's importance is surpassed by another then it will be replaced! Yes and that includes my own... all equals here...
        Post Theme                                                        Maintainer      Last Update (probably... not real-time)
  • Basic Rodin Coil Theory - Early Ideas              Acerzw          28 Oct 2007 11:08
        http://www.overunity.com/index.php?topic=3529.msg56561#msg56561
  • Nutcrackers Coil Numerology                          Nutcracker     21 Nov 2007 09:58pm
        http://www.overunity.com/index.php/topic,3529.msg60505.html#msg60505
  • Basic Rodin Pattern Theory - PDF (on hold)     Acerzw          30 Oct 2007 00:31
        http://www.overunity.com/index.php?topic=3529.msg56628#msg56628
  • Coil Winding Diagram                                      Bocas            06 Nov 2007 01:24
        http://www.overunity.com/index.php/topic,3529.msg57897.html#msg57897
  • Coil Winding Quandry - Which way to wind?   Rosphere       08 Nov 2007 12:59
        http://www.overunity.com/index.php/topic,3529.msg58184.html#msg58184
  • Completed Rodin Coil - A Work of Art!             Rosphere       10 Nov 2007 22:28
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
acerzw
@all
at wattsup's suggestion I intend to contact Marko Rodin to ask if he will participate in this thread and will add any response on this post.
Update: I have today at 28 October 2007 10:15 UK time sent the following message to Marko Rodin using the 'contact us' email link on his website:
Hello, this is an open invitation to Marko Rodin to work with like minds in an open forum dedicated to the betterment of humanities lot in the area of power generation, please pass it on to him...
Marko,
I have had the privilege of working on Overunity.com for some time with a very dedicated group of people who have been endeavoring to reverse engineer a free energy device... Steven Mark's toroidal power unit... this effort has been sustained for 10 years,,, it is not finished, but no working theory is available for the device... so the effort is a struggle... this group has an amazing breath of knowledge and expertise around toroid coils...
I have recently been made aware of your work and being an intuitive person and with the experience and education I have gained from the above group can see that the potential for a free energy device based on your coil design is unparalleled...
I am aware of the control you need over the development of your theories and work based on them, but also note your philanthropic desire to better humanities lot...
I believe I speak for all in the group when I say that it is as goal we all share with you...
I would therefore like to extend a humble invitation to you to work with us if you wish, I am sure many would be prepared to help and put their knowledge and expertise toward bringing your ideas to fruition...
The following link will point you to the groups work on the above mentioned replication effort, which I think will show our seriousness, dedication and credentials (given the number of posts alone):
http://www.overunity.com/index.php?board=49.0
and the link below is to a new thread which I have created with discussing your theories in application to practical devices:
http://www.overunity.com/index.php?topic=3529.0
Kind Regards
Robert ***** (overunity.com forum name Acerzw)
26 November 2007 - Marko Rodin makes contact...
Motorcoach1
I have always been intrested in the Rodin coil set up. this is the first time that I've really looked into this. let's pick out a good base matierial to wind it from so we can colaborate as we work. I'll be studying up and look at all his videos and take some notes. Instead of reposting I'll just be adding to this post. I'll begain each new reply with (update-and the date) so as not to add confusion. This would help if everyone did this on there post. please let me know if you think this would work. the only draw back if may not autosend to Email to let people know of new postings. Mike
Gothic
JLN labs has done some work with these unusual type coils, here is the link:
http://jnaudin.free.fr/html/magvtx.htm
I wish you luck and good fortune with this.
acerzw
@Gothic, thanks for the link, will add that to my first post index... :)
@Mike (Motorcoach1)
Nice to have you on board!  :)
Yes, that is what I had in mind also, though when you have a completely new idea or reply to someone else's post, you probably should start a new post...
As an extension of your idea, I will add an index to my opening post to important posts that are made... these posts can then be updated as necessary and I will put the last time updated on the index next to each entry from time to time..
I personally will not miss the email post update notification, as I will check back here most days... (and get enough spam already.)
Acerzw, making this thread easy to access for newbies and all alike..
