Hydrosonic Pump
Started by FreeEnergy, June 27, 2005, 03:47:29 AM
lltfdaniel1
The water hammer is a cavity effect so it taps zpe as zpe interacts with everything, you can get overunity with it.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
wings
You can download for free New Energy Technologies magazine here:
http://www.faraday.ru/net.htm
the last numbers 2003, 2004, 2005 contains lot of information about heat cavitation devices
in order to have cavitation the tangential speed must be over 60 m/sec, cavitation depends also from pressure in the pump.
some test:
http://www.fieldlines.com/story/2007/10/3/195821/664
jchapman
Having another attempt to get the Hydrosonic Pump working.
Have  a Variable Speed Drive to get it to 6000 rpm and a 500W generator to load it up if it starts to run by itself -also have a water dump value to shut it down if things get out out control JC
Ghost
any news on this?
any replicators?
anything???????????????????????????????
mscoffman
Quote from: Ghost on July 30, 2012, 09:03:51 AM
any news on this?
any replicators?
anything? ??? ??? ??? ??? ??? ??? ??? ??? ??? ???
Well, they work. They produce their excess energy because of cavitation LENR.
Because they have a fluid water "core" where the reaction takes place it is difficult
to get these to show any self-running-loop tendencies, but generally just plain water
excess heating.
If you search for the string "nowak" on this web site. You will find information
on the DRJ200 and other Griggs type heating pumps.  Dr. Nowak is difficult
for us to understand because he speaks in Polish. The only thing I would
advise is that Europe uses 50HZ. electric power so it's motors run at a sub-multiples
of 50 RPS while US. uses 60HZ and AC motors there run at sub-multiples of 60RPS.
So optimal cavitation rotor hole spacing will probably change between these two.
One could use gearing to adjust RPM's. Very efficient electric motors are also required
which needs to be in the motor's specification sheet.  It's unfortunate that Dr Nowak
and associates didn't get their message across sooner because what they had is a
valid LENR  utilization pathway, though it shares problems with all fluid core LENR
reactors. Most people are now working on more direct LENR stuff.
See; http://www.e-cat.com
:S:MarkSCoffman
