Harmonic Oscillating Power Electric generator video
Started by hartiberlin, June 27, 2005, 07:37:55 AM
BushWacker
Hi Guys,
   I have attached the latest updated basic configuration for a HOPE Generator. Instead of leaving one end of each of two of the input coils unwired I have found that in most cases there is an increased efficiency when these wires are connected together and linked to the input. Take a look at the drawing and you will see what I mean.
In most cases this seems to be the best way to wire things although I have assembled a couple of units that had to be wired with the input coils connected to the corresponding coil on the opposite side. There doesn't seem to be a predictable way to know how a particular unit will function or how it may need to be wired to be the most efficient. I have recently built three identical units with the only slight difference being how tightly the coils have been wrapped/wound.
It seems that contrary to my thinking, the coils which have been wrapped more tightly do not work as well as those which have been wound more loosely. This goes for both the input and output coils! I have no explanation that makes much sense to me at this time but I have double checked this to make certain that this is in fact the case and it definately seems to be. The difference in output can be as much as 600+ VAC so this is no small note to make for those who may be building one of these devices. Keep up the good work LancaIV.
Best Regards All,
Jim
TheOne
hi,
i am not good at electronic so here my question/suggestion
for a better core instead of using what you are using, that would not be better to
built your own core using Amorphous Metal, they react faster to magnet field and
using glue they will probably be cheaper then a standard metal core?
BushWacker
   I am currently using an "amorphous metal/glass composite" to build the various models of HOPE Generators. I have so far only used C-core style cores made of this material by Metglass Corporation. My latest model was built with the intention of utilizing AC current directly instead of sound/audio signals which needed to be created by using a small electrical source of origin anyway. The new unit will still convert audio signals directly into AC current but with the limitations of having to use the same old materials I have found that using a small AC input directly gives me a better overall energy coefficient/COP.
I had been trying to convince one of Metglass'es distributors to help me to obtain enough of the raw ribbon/tape material that Metglass makes their AMCC series cores out of but Metglass is treating it as a special order and simply wants far to much for a small amount of the ribbon. The idea was to purchase the amorphous ribbon and some LZT (Lead Zirconate Titanate) from EDO Corp., to dope the ribbon with. A small DC current would be applied along the ribbon over a short distance at a time while a slow drying epoxy/glue would be lightly applied to the ribbon. The LZT nanocrystaline Powder would then be sprinkled onto the ribbon and the crystals oriented in a desired direction by means of the DC current. The ribbon would gradually be rolled into a torroid shape until the desired core thickness was achieved and the new hybrid core would then be allowed to dry/set.
Since the amorphous composite material already shows a response to sound resonance the crystals should increase the response by many factors. The idea was to enhance both the magnetic and pure resonant qualities of the original core material with a highly reactive piezo material to increase the electrical response. Because the LZT crystaline material reacts to both electrical and/or sound resonance I felt that it was logical to assume that the addition of such a material could only increase the output potential of a HOPE style assembly.
Unfortunately money has once again thrown a wrench into the works and I am again unable to go any further. BTW, my latest HOPE model is showing output potentials of between 100 to 150+ times the energy input in volts. The multiplication factors will depend on the waveform and type of energy input but any type of resonant energy can be utilized and converted directly into AC potential. For instance: if I put in say 9v AC even at very low mA levels I will see well over 1000 volts on the output side. Remember that that is 9v AC not DC! If I split 9v DC into 18v AC you would see somewhere around +or- 2000vAC at the output end. This is plenty for providing fluorescent lighting of several full sized fluorescent lights so that is what I am using it for for now. It may not impress to many people but try to find any product on the market that provides this kind of lighting with so little energy. Hey, if nothing else it might interest some hermits or pot growers out there eh? lol
Cheers,
Jim
TheOne
you cannot use magnetite and use epoxy to build you core? i am not sure if Amorphous Metal is made out of this material, but some used magnetite to build coil core instead of metal and get better result, you can buy big bag of magnetic on internet, its something to try out :)
BushWacker
Hi (The One)
   Thats interesting, I haven't heard of anyone using Magnetite to make cores out of. I will try to find some info on that. There are many things a person could try if they have the proper equipment available, and I suppose that I may eventually have the opportunity to create some cores from scratch using various raw materials but right now we are trying to sell the house and there isn't any place to fire up the kiln or even an area to work at other than the floor or one small card table. The overall environment around here is not beneficial to conducting any sort of research either as my folks are in their mid-eighties and pretty much losing brain cells in massive quantities lately, so they keep me pretty busy..... lol.
It appears that I am going to be the only one to take care of them through their final years, and being that I am disabled myself, its going to take every ounce of strength and patience that I have.
God only knows if anyone will ever pick up where I left off but I can only hope that someone will. I really think that the addition of the proper mix of piezo materials with the right core material/s may allow us to break unity by a fair margin but it will likely wind up being someone other than me who will have that honor. If anyone out there wants my help in pointing them to various suppliers or for tips on anything I am more than willing to help. However I have spent every penny I had on my research and have been unemployed and unable to work a regular job now for 11 years so the buck stops here as far as my work goes on HOPE R&D.
I hope that someone will be encouraged by what we've learned from this all so far enough to carry on along this line of R&D because I truly believe that we are ver-very close to seeing the true potential of this kind of technology. I wish I could try Magnetite as well as a good number of other elements and various combinations but it has proven to be far to expensive for one unemployed guy to afford, and much to time consuming as well when you have several geriatric children to take care of.
If anyone does decide to look into this approach further and experiment with piezo powders and various magnetic materials etc.., etc.., I recommend that they start from scratch and stay away from big corporations as much as possible! Before they will help you obtain any materials they have to know what exactly you need it for. Then they will leave you broke, take your idea's, and leave you in the gutter.
I wouldn't be suprized at all to see one of them suddenly come out with an allegedly new idea/invention involving piezo enhanced cores for power applications and/or alternative energy. Most likely though the alternative energy tech would go to the U.S., military and never be seen by the public again.
Oh well, this is startin to turn into a novel so I'll shut up now, lol. I guess the best advice I can give to someone is,......... if you know that you know that you know something will work even though nobody else has a clue about what you are talking about, go for it because thats the way most new discoveries and technologies come into being. Don't worry so much about the current theories in physics as long as you have a good working knowledge and understanding of the basics.
Best Regards All,
Jim
