Harmonic Oscillating Power Electric generator video
Started by hartiberlin, June 27, 2005, 07:37:55 AM
BushWacker
Hi Guy's,
    As you can see Stefan, I'm back. I have decided to put this project ahead of even the ISBP project for the next couple of weeks. My people will understand and they are fully aware of everything that is going on. At the moment I am waiting for a reply from an engineer who has volunteered his help with this project. If he is willing I will be leaving within the next week to run the HOPE Gen., through the ringer and try to find out exactly what is going on. If need be I will leave the unit with him so that he can draw up the specs as soon as possible so that everyone has the complete information needed to reproduce this device in it's entirety. I am happy to answer any questions and am not one to exagerate or embelish the truth. This is a very important issue and believe that hidden facts and details only serve to delay progress in this area. Thanks for all you do Stefan, and let me know if there is anything else I can do.
Best Regards All,
J.D.
hartiberlin
More info from Jim:
Hi Stefan,
     Are you absolutely sure that your estimate of 268 watts is correct? If so, this would mean  either that we actually do have OU going on here, or that there is indeed something very different about this energy which is registering as AC on a multimeter, and that the readings are somehow wrong. I was wondering about this because of several oddities which I have observed. I guess we will have to wait until we can test it with better equipment than I currently have available. Since this is such a touchy subject and because there have been so many mistakes made in the past, I would like to keep any further information on this between us for now. I don't mean that other's shouldn't try and build and test out their own units, I only mean that I am leery of making free energy claims before every last effort has been made to verify all the findings as being accurate. BTW, the sine wave that I am using on the CD is a pure sine wave. Thanks a bunch for giving me the scoop on the wattage values. As for the way the magnets are situated inside the core, they are placed lengthwise along the line where the two halves of the core meet together and are superglued in place. The SmCo magnets measure exactly 1" Long x  1/2" Wide x 3/16" Thickness according to U.S., standard measurements (or)  25.4mm Long x 12.7mm Wide x 3.175mm Thickness according to the metric standard. The magnets I used are grade #17 and were purchased from the ForceField web-site at (http://www.wondermagnets.com/). One more very important note that you will not be able to notice from the photos is that one wire from each of the four input coils is criss-crossed over to the other input coil on the far outside corner contact (or) last screw on the edge of the two top contact strips. In other words, if you draw an X from the outside screw of each of the two contact strips which you see on the top of the unit, that is how the four input coils have been re-wired. Another trickey part is the way that the stereo audio jack is wired but thats a bit more complicated and will need to be drawn out on paper. The rest is fairly simple but very odd as I have said, and can be seen fairly well in the photos. I am sorry that I don't have a very good camera right now, and hopefully someone will have one we can use to take better pictures once I get to Utah. Also, Sterling and his engineer's will then have a chance to take a look at it all and test it out for themselves. It does give me even more HOPE after seeing the figures that you have given me concerning the output in wattage Stefan. Lets keep our finger's crossed that this is really it this time eh? We've all worked and waited a long time to see something actually come out of all of this effort, and it would be a real blessing to know that it cannot be patented by any one person now. I know what I'll be doing anyway if these readings all turn out to be accurate. I'll be the first to set up for full scale production in my area, lol. Oh BTW, I almost forgot about the extra transformer. This has enabled the HOPE unit to use even white noise as a good input source for some reason. I don't know why, all I know is that it works very well. It also seems to boost both the voltage and amperage somewhat and so I'm sticking to what works right now. Since I have also found a way to pass the audio signal directly through the unit at no real loss in power, I figure that it should be possible to power several more units with the same audio input signal as is used in the first module or unit. This would really increase the input to output ratio's and I am eager to try this out soon also.
Cheers,
Jim
Stefan Hartmann <hartiberlin@gmx.de> wrote:
Hi Jim, thanks for the new infos and the pics.
It is now all posted on the same thread in :
http://www.overunity.com/index.php/topic,358.0.html
To your questions;
>. It is very clear however that this technology is very energy efficient if nothing else, as the portable CD player I bought uses
only 2 AA batteries and when I play a 16400Hz sine wave from a CD recording I made on my PC, the voltage goes as high as 400VAC at
.67 Amps. Perhaps you could tell me what that figures out to in Watts?>
Normally, if you have DC you can just multiply the values to get the Wattage.
But at AC you have to multiply in the phase shift between current and voltage
with Cos Phi
as a factor between 0 and 1.
If it is pure sine waves it is easy.
It gets more complex, if it are not sine waves...
So, if the phase shift is almost 0 degrees you have to
cos phi= 1 and the factor is 1 so you can just multiply voltage and current
to get the Watts, that would be:
400 x 0.67= 268 Watts.
Could you still show, how the core is fixed to the magnets
and why you need an additional transformer ?
What is the additional transformer doing ?
Thanks.
Regards. Stefan.
hartiberlin
Hi Jim,
268 Watts is probably not the case, as you just light up 2 x 8 Watts fl tubes and 2 x 4 Watts bulbs ?`
So all in all I would say that you are able to generate about 10 to 30 Watts with it in the moment,
so there is probably a phase angle between the 400 Volts and 0.67 amps.
Also meters built for 60 Hz AC won?t measure correct at 16400 hz !
So you better make a drawing of all the wiring and let it be scanned in from
somebody who has a scanner and then you can post this.
Maybe a neighbour of you has a better digital camera ?
Your pics are rather difficult to see, cause they are pretty blurry.
So if you put out about 10 to 30 Watts right now with your 4 tubes,
how much are ou putting in ?
A soundcard can only deliver around maybe maximum 2 Volt AC peak to peak and only
a low current, maybe 500 mA max. so this would give only about 1 Watts of output power.
So maybe we see here already a COP of at least 10, so efficiency is around 1000 % ?
Regards, Stefan.
hartiberlin
Hi Stefan,
I have pasted below the report on the latest tests which we conducted on the HOPE device.
I don't know if you want to post this on your forum so I am leaving this up to you to decide.
Hope your doing well Stefan.
Best Regards,
J.D.Fauble
_____________________________________________________________________________
Shalom Y'All,
As you may know I have just returned from visiting with Rob, and we
found out that the current readings were apparently lower than my
multimeter was showing. According to a test using a bridge rectifier
which Bill described to Rob, there was almost no current behind the
high voltage.
I trust both Bill and Rob more than any other friends I
have known throughout my life and am honored to have such great men
as these in the ISBP Project forum.
However, my own personal opinion however is that we
are dealing with a slightly different type of energy which is being
created as the result of the sound energy reverberating through the
various materials which make up the device itself, and is possibly
producing more than just electrons.
What I have seen through the
various experiments which I have tried is that there seems to be some
type of plasma being created which does not act like the AC or DC
electricity that I am familiar with. I don't believe Rob shares the
same opinion, and maybe he is correct, however I am fairly obsessive
about details and am not ready to make this conclusion yet.
I know
that measuring AC current is no easy task, and a good many people
have made the mistake of claiming free energy because of this. This
is why I am very cautious about making such claims.
It is also partly
the reason that I am not so quick to conclude that there is not
something more to the HOPE unit that we do not understand yet. Bill
has a very interesting theory which delves beyond the current
understanding of physics, and which explains some of the anomalies
which I have noticed while experimenting with the device.
Bills
theory would confirm my hunch about what is going on inside the HOPE
unit. If Bill is right, it would mean that the sound input is
basically causing echo's in the unit which produce interjecting waves
within the core and copper coils.
If you understand how a gas laser
works then you may be able to see how sound could actually be
converted to light, or some type of plasma energy when a certain
frequency is achieved.
On the other hand, the trip to Rob's revealed
another oddity which I have yet to understand but could also be
valuable information to find out. When Rob and I ran the frequency
settings which work best at my house in El Paso, we found that we
were barely producing any energy at all.
When we ran through a few
frequencies between 40Hz and 20KHz we found completely new prime
frequencies for Rob's location in Utah.
Personally I find this very
interesting and would like to see what happens when I bring the unit
over to Larry's place about 40 miles from here. What would cause the
various changes for prime frequency settings from one location to
another. Could it be lay lines, or are various radio and/or cell
communications contributing to the function of the unit? You can
probably tell what I mean about obsessive now eh guy's? lol.
Another reason for my continuing enthusiasm concerning the HOPE unit
is the fact that it does directly convert sound to some form of
electrical and/or plasma type energy.
I am interested to see if the
device might be useful for cracking H2O since both sound and
electricity have been used for this purpose for some time already.
Neither Rob nor myself felt that it was worth the while to draw up
the specs to reproduce the device yet, and unless we do find
something more promising than what we have so far I don't think
anyone else will want to waste their time.
I will begin the H2O
experiments within the next week,and I will be purchasing the wave  generator soft ware that Rob
uses so that I have more options and frequencies to work with.
Right now some of you may be thinking that I should change the name of the unit to the WISH Generator lol,
but I stil lhave some HOPE for the time being, and time will tell whether
there is any thing more to the device.
One of the things which makes things interesting is that we all see things from our own various perspective's,
and life would be pretty boring
if we all thought exactly the same about everything.
Of course that is only my opinion.
Cheers All,Jim
hartiberlin
Here is an update from Jim:
Hi Stefan,
    There is some progress on the HOPE tech and I have been able to double the efficiency of the original unit within the last two weeks. It appears that both geographic location and temperature help to determine the prime operating frequencies of the HOPE generator. I've also re-configured the wiring between the HOPE unit itself and the antique transformer that I have been using with it. The new configuration works well and is much less complicated than the old one. A small group of private investor's want to take a look at the device and are flying the best engineer they know of to El Paso in about six weeks as things look now, and we will be working on building a small audio amp circuit which we will try to tune to give us audio feedback at these primer frequencies. I've already tested to see if audio feedback would work and it seems to work better than any tone generator that I've used so far so things are looking positive. Another thing that we figured out is that the diodes that the guy used to rectify the AC in order to test the current output were slow diodes and did not reflect the true amperage. I already knew that the readings could not have been correct because I've nearly been knocked on my backside several times by accidentally touching a couple live leads. I have a lot of personal experience with getting zapped by electricity and I can tell that there is much more than just high voltage with no current coming out of the HOPE unit. I haven't wanted to make to much more known at this point but I am working on that step-by-step manual, and will be sending it out to my friend's and collegue's as soon as it's finished. I will probably have some time to do this now while I wait for the backer's to show up as I don't want to even touch anything until they do. I think were getting a good idea of what is going on within the HOPE unit to cause the kind of output we are seeing and believe that it is due mainly to the nano-crystaline core material that I'm using as well as the way I have the wiring configuration set-up. Now if we can build these things to resonate at healing frequencies that would be yet another plus, lol. The system is built to be modular so that other units can simply be plugged into the previous units and all use the original sound source to increase the energy output. There seems to be no noticable loss in output to the existing unit in the process and so this is a major plus in my opinion. Although the HOPE will produce an impressive amount of output without any additional transformers attached, the particular antique style variable transformer that I am using with my unit does seem to improve on things in several ways. The additional transformer that I am using enables a wider range of prime frequencies to be used, and also helps to increase the voltage considerably. This works great for lighting, however we will have to see whether we will want to use an additional transformer for every other application. There is a lot of work yet to be done thats for sure. But even in this infancy stage the HOPE is looking very impressive to a lot of people including myself, and I can't see any downside to the technology yet. I am forming a partnership with another very intelligent young man in N.Y.C., and we are hoping to be able to bring many more valuable technologies to the people very soon. I won't even go into what we are planning to do for now, but I know that you will be very interested in them all. I believe we all need to take a closer look at crystals and nano-crystal materials and consider sound as a source for energy. It does make sense when you think about it don't you think Stefan? I am supprized that Tom Bearden hasn't picked up on this bigtime yet but I'm sure he'll catch on soon if his health continue's to permit. I've been wanting to be able to talk to Tom for a long time because I do think he is a very smart guy and that he is right about many things. I wish someone would give me a number or address where I could contact him. Anyway, I wanted to tell you that I am making progress on the HOPE tech and have people lining up to look at it and HOPEfully develop it so we can all use this stuff. My partner in N.Y., tells me that he has several hundreds of people who all want to buy one of these units right now, but until we get that mini amp circuit built in I don't want to make any public claims just yet. We're also still looking for 400 series stainless sheet metal to build our wave guides for the ISBP but are having a heck of a time finding it at any reasonable price. Seems like all the industry has gone to China and Mexico, and I think the citizen's of the states are going to suffer greatly for the insatiable greed of the executive's who have been making these kinds of decisions throughout the last couple of decades. Well, don't want to talk your head of buddy so I'll let you get back to work. Take care, and I'll be staying in touch and keeping you up to date on things as they develop.
Best Regards,
Jim
