Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
@ quantum1024
As of now, this is nothing more than probably just an efficient circuit, so there is no involvement of the earth's magnetic field.  But that is why we want to change the frequency to 7.3 or 7.5 Hz.  Please refer to Marco's dancing magnets to see the wave that can be tapped there.
@All
I believe three things are needed here, to even approach using the standing wave.
1.  The right frequency
2.  Higher voltage (equals speed)
3.  Counter Clockwise windings.
Holiday Cheers,
Bruce
quantum1024
Do you have a link for this..... Marco's dancing magnets
sanmankl
Quote from: btentzer on November 25, 2007, 10:38:30 AM
@samnakl
Please remember that EM stated that his LED was some super efficient hybrid type, and that is why it ran so long.Ã,  He used a regular LED and he said it ran for "a little bit" but never gave a time.
I want to stay away from increasing the efficiency of the LED or increasing the Main 1000 uf cap size and learn how to make this thing rock using "other" methods, such as coils, types of wire, frequency close to shumann's, etc.Ã,  This is the base line I have set for my self.Ã,  Just blinking an LED for a length of time does me no good, unless the coil is directly involved.
Your test with the iron wire core was "inspiring".Ã,  can you also test 4Tesla's circuit, to bring the circuit down to around 7.3 Hz if you have a scope.Ã,  Also a current reading would be awesome.Ã,  Thanks!
Hi Bruce,
Yes, I do understand that EM is using super-efficient LEDs (so am I, bloody expensive too.)Ã,
So far, I've "revert" to my copper-only coil (I have recoiled the iron coil since) and the run time I got tonight was kinda strange.
Based on 4Tesla's circuit, I have "tuned" the freq to 7.5Hz by adding a 2M2 pot. and below are the test results. I ran the each tests twice to verify result.
Configuration
- Torroid core .75" Ferrite (dark grey)
- AWG 23, 30T, 15T and 7T (as spec'ed by EM)
- 220nF cap, 2M2 pot tuned to 7.5Hz (drift + - 05Hz). Measured with DVM across the LEDs. Main cap charged to 9.17V with 9V batt.
- 3mm Blue LED, super-efficient (over here, they called it super-bright). I don't know if it's a "hybrid" thing or not?
-Ã,  1 LED, 29m30s
-Ã,  3 LEDs, 31m10s
-Ã,  5 LEDs, 31m
So, I guessed that the run time is better with a "load"? I'm still trying to figure this out.
Next, I'll measure the current consumed by the single LED and also use my "iron-wire" coil (wound onto a 1" torroid) and post the results.
Cheers, cp
EDIT: I'd got a business trip to make next week so I can only do all these testings when I get back.
hartiberlin
Maybe EMdevices circuit was running so long, as he used a trifilar coil and as he had 2 windings of it in series, he is also using the Tesla flat coil effect to enhance the capacity of the coil.
If capacity rich coils are switched they might generate more BackEMF power and thus recharge the main cap much stronger....
So it is wise to use this trifilar coil setup...
Maybe even multifilar and putting all windings in series...
