Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
quantum1024
I had a bunch of cores laying around, I thought maybe I should check them sorta magnetically, so I played with about 15 cores and stuck a neodymium magnet on them, interestingly they where all different strengths, when I tried to remove the magnet from the cores. There where stronger and weaker cores. Try this test yourselves.
wattsup
I got a transistor that is equivalent to the MPS3904 which is a MPS6514 and the LED is now BLINKING. (Applause accepted). I can see on my scope that there are large spikes but taking a picture of it will be difficult on my old Hitachi V-650F cause the spikes are moving really quick.
1) Can any of the EEers here explain to me why this circuit is blinking the LED. Does this not mean that the base is getting zero voltage - then voltage - then zero voltage. But how is that possible?
2) My large cap is a 1000uF 25V. Does this mean that if I only charge the circuit with let's say 3 volts, I won't have 1000uF, or do I have to charge it for a longer time for it to reach 1000uF.
Bruce_TPU
Quote from: wattsup on November 25, 2007, 06:36:06 PM
Great job, Wattsup!  (Applause!)  It seems to run longer with a larger load of LED's, so you may want to start with at least two in parallel.
Is your transistor hooked in reverse as mine is?
Holiday Cheers,
Bruce
hakware
In regards to 7.5Hz resonance, an LC circuit to resonate at that frequency with a toroid core of the sizes were using
would be around 200 winds of wire and about a .4F capacitor. So there must be some other mechanism at work here.
we don't have near enough wire or cap size for it to have the resonant frequencies that it appears to be exhibiting here.
just my .02
@EMdevices
Do you have a part number on that core your using? numbers printed on the outside circumference?
4Tesla
Here is a site that sells both ferrite and iron toroid cores.
http://www.oselectronics.com/ose_p88.htm
I would like to buy 2 of each kind.  What size do you think works best?
There are 4 different mixes - 43, 61, 75, and 77.. Which do you think is best?
Thanks,
4Tesla
