Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
eon
im down to my last bc337 and i blew up my large blue led. anyway ive now got to grips with swapping things in and out without damaging them. as you can see, ive got no breadboard (yet), so its all a bit of a fiddly solder job.  im an electrical fitter or electro-mechanical engineer so electronics is not my forte.
im not going for length of operation until i have a greater range of components, but more to establish a model and vary it.
im happy to report that
identical cap outside the core at 9.6v gave run of 7.06, 7.08, 7.07 mins
identical cap (minus wrapper) inside core, gives 7.47, 7.43, 7.47mins
4Tesla
Interesting!  So having the cap inside the core adds about 40 seconds!
One thing I would like to know is run times at 2hz, 4hz, 7hz, 14hz, and 30hz.  If the runtime shortens by about half each time upped then we can conclude that the frequency doesn't effect the efficiency of the coil.
Edit: or 2hz, 4hz, 8hz, 16hz, and 32hz
4Tesla
4Tesla
I went shopping!  :)
I bought 2 of the FT114-77 1.14" ferrite toroids, 1 of the FT140-77 1.4" ferrite toroids, and 1 of the T106-26 1.06" iron toroids.
Site: http://www.oselectronics.com/ose_p88.htm
I also bought some red and green 20 gauge colored magnet wire (copper).
Site: http://www.bulkwire.com/colored_magnet_wire.asp
I'm going to buy some 20 gauge iron wire from my local Grainger store.. Grainger Item # 6A852
Site: http://www.grainger.com
4Tesla
Bruce_TPU
@ 4Tesla
I think you should try the iron core.  I have it on good authority, that good things can come from iron cores, but not sure if so with this set up.   ;)
@ All
Hey guys,
I have been working feverishly to increase my time past 30 minutes and to no avail.  I have burned out all but three LED's and my best transistor.  I replaced the transistor tonight, and saw that my barium ferrite am radio antenna core coils have arrived!   ;D  Now this will be fun!  And we need to boost the voltage, but not the total wattage.  High voltage equals speed, and we need speed.  So any ideas to easily bump the voltage, would be helpful.  I am thinking of adding some part of the cold electricity circuit to this circuit.  That is my plan.
I will let you know when something good comes, and I hope that it will!
Happy experimenting and happy holidays,
Bruce
EDIT:
@ 4Tesla
Please post the link to the iron wire, I could not find it on the grainger site.  Thanks!
BEP
@btentzer
WW Grainger #6A852 is 'J' type thermocouple extension wire. It is composed of a positive leg of iron and a negative leg which is 45% nickel and 55% copper.
Select 'Grainger item number where 'keyword' is shown and put the 6a852 under that and click 'go'.
Interesting use of T-couple wire. Never thought of that! Might be interesting. Other types may be more interesting  :)
