Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
0 Members and 28 Guests are viewing this topic.
Bruce_TPU
Hello All,
Well, I have run my last test for the night.  No joy from any of my earlier tests, BUT on this last test, I took the wire going from the anode of the LED to the primary bottom winding on the barium ferrite coil core, and moved it to the negative side of the capacitor.  I have one lead of the secondary from the barium ferrite coil, going to a 1N4007 diode and from there to the positive side of the 1000uf capacitor.
The LED lit MUCH more brightly per flash.  To the point that it hurt my eyes to look at it!   ;D
Total run time was still just over 37 minutes, though.
A new round of tests tomorrow night.
Holiday Cheers and good night,
Bruce
Pirate88179
tosky
The newest torch design use super-cap. to replace the battery. So there is no special to use Capacitor to power your circuit. It is a good start to have a close loop circuit for O.U. research. Because it could prevent wrong result of getting energy from power supply or battery. Some guys waste long time to develop their devices, finally they realize the energy actually from power supply or battery. This close loop circuit is very good to evaluate where can get the energy, From vortex, ether, schuman resonance etc. I think it is wrong to increase the Capacitor to get the longer life time. It should be decrease the Capacitor, and tap to where possible energy source to extent the life time. This is more sensitive to find out the external energy. This circuit should be used as a (Energy- Probe). We don't need a Super Cap. Torch.
4549raymond
Bill perhaps you could amplify a little and tell us why you think this is amazing. I think 37minutes with this setup is significant.If it can be tuned to the point that it does not run down without recharge then Bingo -truely amazing and in fact seriously significant. Until then I adore the approach of these dedicated experimenters
tosky
Using the precharged energy to run the circuit is nothing new. More important is to use close loop circuit as an (Energy-Probe) to do research like a compass show you the way to O.U. Only a very little charging energy to startup. Then running forever.
