Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
hartiberlin
Hi Fausto,
what is exactly the MOSFET doing inyour circuit ?
Is it acting with its gate like an antenna for the oscillations
and then the MOSFET also oscillates ?
2. Why are your scopeshots so "blurry" ?
Is there much radiofrequency overlayed inside
the traces ?
Or can?t you sync the scope  to the fastest oscillations ?
3. in your 2 circuits setup, how do you feed
each circuit with each others ?
Many thanks and keep up the good work.
Regards, Stefan.
ilangiat
dear plengo
there is a posibility to make a nice diagram of your device?
i was trieing to folow your old diagram, but i couldent, there was no windings Nr. and so on
i find your device beutiful, while loadind up the battery, so please make a nice diagram, you know how much we want a nice replication
ilan
Harvey
Hi All,
This is a beautiful thing to see.
7.8Hz resonant circuit right?
Sync'd up nicely with Schumann Resonance?
35 pages here, I guess I'll see if theres a schematic in there somewhere.
Cheers,
Harvey
wattsup
@btentzer and @all
Good going.
I went to my EE surplus place and spent a good 20 minutes rummaging through a mixed transformer bin and found this small transformer ($1.50) with two primaries and two secondaries, all isolated.
Used one primary and two secondaries.
Put it on EM's classic circuit.
Gave it 9vdc for three seconds and it ran and ran and ran for a whooping 9 minutes 10 seconds. For the first time, I could see it flicker fast although very low intensity, but 9:10, wow, that's my record. It lit for longer but the LED was really really low.
I can try with both primaries in parallel or in series or in mobius.
There is potential here since having this working circuit, I can now test with adding an aerial plate on the positive and a ground plate on the negative. Or other tests. Great.
This is great because it gives me a standard and any tests deviations will help me learn. Just great. I put a photo below.
@btenzer, how did you start your non-battery trials. I used 9 vdc for 3 seconds.
I think this would have to be standardized also.
I have a story about a battery, but did not know which thread to put it in, so here goes.
This was told to me by a guy that was at my home with three other inventors for four days of working on an potential OU device. (Big gears, motors, etc.)
It is about a guy in Quebec that invented a battery about 12-14 years ago. He could charge up cars continuously until the battery was too low, recharge it for 10 minutes and it would go back up to full, then continue like that, day in day out. He told me that the inventor had made and sold some of these batteries but eventually he was told to stop everything because the authorities were afraid the batteries would blow up. Yeh sure.
Anyways, he gave me some places to look for the inventor in the Montreal area, so the next day I called a few major battery stores that were in the vicinity and spoke with the president of one of these. I related this observation to him and asked about this inventor.
He said the inventor was not from his company but that he remembered also some guy that was making super power batteries. He said he had died but that his son took over. He also mentioned that what he would do is take marine grade deep charge batteries, remove about 1" of the acid solution and replace with 1" of vegetable oil. Apparently this mixture gave the battery extreme power and durability plus fast charging. Maybe I should try this but first I would need some protection, just in case the authorities were right.
sanmankl
@all,
Wow! 10 days away and all these development. Certainly needs some fast catching up. So, there's at least 2 circuits that I would like to follow?
1. EMDevices or it's variant. Maybe the one from Bruce being the latest?
2. Plengo's.
@Plengo,
Understand that this is a "living" circuit subject to changes and modification but looking at your photos only serves to confuse me.So, would it be possible to at least draw up a circuit diagram and use that as a base for us to replicate?
Great work.
Regards and happy holidays,
sanmankl
