Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
plengo
@btentzer
and the worse is that I am still working on it measuring to have a proof that it does not work. That's my love for science.  ::)
I still have another one that works a little bit different and is still running inside my Faraday's cage. It too can run for 500+ days or even more but that one there is not problem with the gate thing because there is not mosfet.
I guess, I am back to the next level onto the N.Tesla 4 Switch device.  >:( ;)
Fausto.
Groundloop
Bruce_TPU
Quote from: Groundloop on December 22, 2007, 02:32:10 AM
@Plengo,
I do not know where you got the +500 days from. If you run the LEDs ( I use 5 leds) at full strength then
you will draw approx. 100mA/h from the 160mA/h battery. The battery will then last for under two hours. In your case where you are drawing 0,2mA/h from a 160mA/h battery then you will drain the battery in approx. 800 hours. This is close to 33 days of run time.
Groundloop.
@ Groundloop
That was my bad, I had figured total battery wattage vs. discharge, not simply amp hour usage.
magpwr
Hi @All,
Is this project  busted?   Quote from Myth Buster.
I am about to embark on a a new project related to overunity early next year.
This time it has nothing to do with magnets,coil or electronics.
I 've discoverd this site www.glopaint.com where they recently discovered Litroenergy - a new form of light source which  doesn't require battery at all.It will produce light for 12 years without batteries as they say it's non radioactive.
My plan to purchase this early next year and stack solar cell (eg: on both side of A4 size product.
The cost as mention to light up 8 ? x 11 piece of plastic 1/8? thick is about .35 cents.
I believe this thing may have the potential to generate small amount of power to tricke charge my phone or laptop for many years .
I'm sure somebody or myself will start a new post over at overunity.com related to this project on litroenergy,no soldering or electronic experience may be required.
Quote for the day.Remember to keep information open unruled by EGO, it will benefit mankind in long run.
wattsup
@Plengo
Keep your chin up.
I'd take 33 days over 500 days.... any day. So the goose is not cooked yet. Plus it is not really 33 days but the days it would take for the voltage to arrive at a non-usable level, so that would be less then 33 days.
Imagine all the 9 volts batteries that run devices that require 9 volts and once the battery goes below the usable level for that particular device, people just throw them away. What a waste.
@all
I have plugged my last circuit that lasted 9 minutes onto my super dead 9 volt battery plus a super dead 41,000 mfd 25 vdc capacitor, plugged them in parallel and put them on the circuit. Voltage is now up to 2.964, the LED is lit but very lightly, but voltage is going up. It has been over one day.
Again, this just shows the circuit is living. This is a good base to expand from and try so many other things so it's all great for me.
What if instead we send the LED output to the primary of another coil and the secondary back to the circuit input via a diode. Maybe that would loop the loop. Then put the LED on the negative of the primary and the positive of the secondary.
Question for the EEers. Is this circuit working with AC or DC. On another thread we had discussed already that DC to DC transformers do not exist because you need a an alternating current to create the secondary outputs, so this has to be AC, or is it DC. I mean I am measuring in DC 2.94 volts, and on AC there is only .3mV, so why does the transformer work, or why would a toroid work?
@btentzer
Nice post on ottos' new thread. Lit'z spread the word. I am preparing a post for there but I feel it is too long. I can't believe otto is posting so often these days.
