THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
Vortex1
Quote from: Sequental.9 on September 05, 2016, 12:15:12 PM
Who is this man and what is he doing ?
I don't know who the man his (forgot his name) but that picture was used to depict an experiment done by a couple of individuals whereby an RF field placed across a quartz crystal caused it tp not only expand to several times it's normal size but supposedly it also levitated. Truth or fiction, I don't know as I never did the experiment but found it interesting.
I believe the plates shown on either side of the crystal is where the RF is injected, so the crystal is in effect between two capacitor plates with a field that is uniformly vibrating at a high rate.
The hypothesis is that crystals in the natural environment grow by the transport of electrons (from the bottom) that are deposited on the top of a crystal, so they grow by adding progressive layers to the top.
Whether an RF field can accelerate the process is yet to be determined. We know that certain crystals expand when a voltage is applied, we call it piezoelectricity, but what is it really?
I'm willing to give S9 the floor and expand his ideas to an understandable level. Whether they will result in one replicable experiment that proves the correctness of his ideas is yet to be determined.
Thus far I still await a proper connection diagram and clear set of instructions how to proceed so I am on hold with the experiment.
I assume that S9 has already done the experiment knows the truth and wants us to learn, but his communication skills and knowledge level are far different than what most of us are used to the story is getting lost in the telling. I have found this to be the problem with savants I have dealt with in the past.
That is one possible explanation for what is going on with this thread. There are other explanations I am certain, I am not inclined to go there just yet. In the past, I would have.
Kind Regards, Vortex1
Geometry and numbers makes the Nature genom.
materie: positive charge anti-materie : negative charge
Sequence9,proton and proton black hole.
What is about the anti-proton ? http://kworkquark.desy.de/lexikon/lexikon.antiproton/1/
Vortex1
OK now I remember it was Kowsky -Frost experiment from 1919
Here is the link to one article: http://keelynet.com/gravity/kfrost.htm
As I am a bit bogged down with other problems, it may be a while before I can get to any experimental data.
Meanwhile, why not show in more detail some of your positive experiments and the outcomes of them.
For others that may be interested here is a short summary of the specs on my Variac
Prepared for Sequental.9          2 Sept 2016
Superior Electric Powerstat, Model 10 (Vortex1 Variac)
Weight: 725 Grams, 1.6 Lbs.
Dimensions:
Outside Diameter: 71.65mm  2.821 inches
Inside Diameter:   28.30mm  1.111 inches
Height:                  38.75mm  1.525 inches
Wall Thickness:     21.51mm   0.848 inches
Wire Thickness:  0.30mm   0.012 inches
Number of Turns = 563
Length of Wire = 250.82 feet (3009.78 inches)
Terminal #1 = Line Low Side and Output
Terminal # 2 = Line High Side (If only 120 V out required)
Terminal #3= Variable Output Slider (main output)
Terminal #4 = Line High Side (if extended voltage to 132 Vout is required).
Maximum Amps= 1.25
Inductance  1-2        0.95 Henries
                  1-4        0.71 Henries
DC Resistance 1-2      23.7 Ohms
                      1-4      20.8 Ohms
Temperature rise and other data to follow
Vortex1
Quote from: Sequental.9 on September 05, 2016, 10:40:23 PM
The other thing to consider is insulation and it will need more varnish but an inert one !
S9
Attached is a pic of my variac, and also a view of the terminals. I still await a schematic, connection diagram and test procedure.
Please make a simple drawing with terminals 1 thru 4 clearly marked as to what they are supposed to connect to and the rest of the circuit.
