New high volume low voltage electrolysis from Linnard
Started by hartiberlin, November 25, 2007, 11:25:50 PM
hartiberlin
Hi All,
here is a new video I did get today from Dr. Linnard Griffin.
It shows  quite nice hydrogen production from pretty low voltages.
He writes:
Hi Stefan,
Here is a video of my latest discovery. I have broken the 1.2 vdc barrier. Hydrogen and oxygen at below 1.2 vdc with no loss of electrode weight or consumption of metals. I have a volt meter connected to the power input on the cell.
I have a circuit running the reaction. The patent will be published in about one year, then everyone can reproduce it.
As demonstrated by ResinRat2, the size of the reactor will determine the output.
By my calculations the footprint for a reactor to supply hydrogen for a 10 KW fuel cell is one cubic meter.
I think David is a great researcher and scientist.
Feel free to post the video.
Keep up the good work.
Linnard
Super God
Sweet.  It just gets better and better! =)  I can't wait for this new cell to come out.
>9000
ResinRat2
Wow, I guess he liked the report.
I am humbled beyond belief.
(speechless)
ResinRat2
Hi Everyone,
Very interesting video. I would guess (just a guess) that this is probably based off his other Linnard Griffin Electrolysis system.
Way back in June I posted an idea from experiments I was playing with using two tungsten/carbide rods in a NaOH/Colloidal Ag and Mg solution and powered with a AA battery. I was able to get out loads of gases at very little power output. Here is the post:
Quote from: ResinRat2 on June 15, 2007, 07:53:40 AM
Hi All,
I am a firm believer in open-sourced information. This is for anyone using an electrolyzer that uses two stainless-steel electrodes to try.
Electrolyte solution:
10 grams NaOH
20ml of 20ppm concentration of colloidal silver (silver colloid)
10ml of 20ppm concentration of colloidal magnesium (magnesium colloid)
bring this mixture to a total of 100ml with deionized or distilled water.
Using this formula of solution, try it in your electrolyzer with two SS electrodes and see what kind of output of hydrogen and oxygen gases you get. My testing shows it very effective and I want everyone to see this. Try it on your high voltage system too. I get great results just using a AA battery and I am using two tungsten/carbide electrodes.
This is something I will pursue at a later date. Right  now I am working on my fuel cell electricity generator.
The thing I would change here is to leave out the magnesium colloid and just use the silver colloid. Since there is no zinc, there is no need for the magnesium. The silver colloid can regenerate itself off the electrodes. Make up the above solution and add two SS electrodes. Apply a voltage, positve on one electrode, negative on the other, and see what kind of gas generation you get. This was something I never pursued because it needed outside power to run it, and based off some experiments that Dingus Mungus did there was a bit of a temperature rise in the solution; but if Dr.Griffin is now using outside power then perhaps (just a guess) he is doing something similar. The other thing to note is that he is using a pulsed system. Those of you who know how to pulse the power output would probably be the ideal candidates to try this.
If gas generation is not that great, then add the magnesium colloid and see if it makes the difference. I don't think you will need it though, but you might. This stuff is cutting edge technology and we are all exploring the unknown anyway.
I hope someone tries this.
Good luck and thanks for your interest.
adamhy
Hello,
Is there anyone know how to make magnesium colloid?
