Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
Grumpy
        -Frank Edwards
Bruce_TPU
Quote from: Grumpy on December 31, 2007, 11:30:29 PM
What about the statement by SM that the frequencies are "directly related to the circumference of the collector"?
and the comments about "exciting" the collector...
Ring resonator
What about the width of the ring (not diameter)?
Ring resonator tuned to reject even harmonics
A ring resonator an be a hollow toroid, it can be a solid conductor, it can be open with a gap, it can be a closed ring, it can be made of several sections that approximate a circle.
So, both the control windings and the collector could be "ring resonators" tuned to the same frequency - like two tuning forks.
EDIT: you can also create rotating fields in ring resonators.
I read that tubes only put out natural odd harmonics, and solid state, even.
Tube oscillators anyone?
That is what I believe SM meant when he said to just build a tube amp, much quicker all around.  I do indeed think that we are looking for odd harmonics.
SM also said it would take 100 years for someone to find the correct frequencies.  Let's hope not!
New Years Cheers,
B ruce
innovation_station
 8)
those freqs were found months ago
lol
ist
i find it funny if you think you need 3 freqs to heterodyne
i have done this with 1 freq hell even a square pluse  ;)
hummmm    got ya thinking now eh!!
Localjoe
@ Is Tell us how your 2.5 hz square wve works out
@Wattsup
you wrote this
I imagine SM is always asking himself why the hell he ever had to say the third because this is sending us on the wrong track. At the time, ideas were being shot all over the place like a truck without a steering wheel and I think most of what SM said was to try and keep the truck on the road while it was zig-zagging at high speed.
Grumpy had a picture of an electron lattice diagram that dissappeared i cant find it now... Id say thats a pretty good description of it.. As well this page is worth the quick read http://homepage.mac.com/stevepur/physics/matter/matter.3.html
Joe
Edit: Found this in a physics fourm from a gentleman named zephir
The electron is composition of two perpendicular torsion vibrations of vacuum of the different radius ratio. The one helicity is the source of weak charge, the larger one is the source of EMG charge. The picture below demonstrates the relation between the electron and neutrinos. It can be expressed as the planetary system of photon and gauge boson, revolving each other in one closed loop. The spiral (knot) model is just a scheme of path of vibration motion, the real shape of electron is toroidal duality.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Grumpy
What is the "frequency range" of the tubes that SM referenced using when he found the chord (three freqs)?
        -Frank Edwards
