gravito-magnetic ( Imris Pavel patent CZ9401781 !)
Started by Drannom, December 02, 2007, 11:33:51 AM
Drannom
Quote from: fletcher on May 03, 2008, 07:08:11 PM
Drannom .. sorry, the Marquis of Worcestor's wheel didn't/doesn't work - well, not unless you include the addition of hand impetus from time to time to give it momentum & velocity ;)
Do not be sorry, you may get right !
His notice of this exhibition was not written by the Marquis until 1655, from 14 to 17 years after its occurrence, and he may have then hesitated to say that it was not a success; but he may have persuaded himself that he was at last in possession of the secret that was at first wanting, Besides, we are not to infer that the company described as being present had gone to the Tower purposely to see the Marquis's wheel; it being far more probable that, Charles the First and the foreign ambassadors were there to view that fortress with all its treasures and curiosities.
According to the state of knowledge in 1663, the Marquis of Worcester was singular in entertaining this subject, and all we can make of the present article is, that he left it open to doubt whether he himself did not consider that his experiment required confirmation. " Perpetuum Mobile; or a history of the search for self-motive power," 1862, is a work which may be taken as an elaborate note on this article, for it was the perusal of it that led the author, to commence the compilation of that work, more than thirty years ago.
so, i wonder why this wheel could not work, may some bearing make the difference ?
and, the gravito-magnetic wheel, the first one above still need to be prove wrong !
i have notice that magnets are passing between metal plates and then loose power, when magnets get out metal plates there is others magnets enter metal plate, so the rotation must be smooth !
i may test those wheels, some one here may test it sooner !!
bye
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
Drannom
i finally found the link from the quanthomme french website !
Imris Pavel is the inventor of this gravito magnetic device!
patent CZ9401781
it's in a new from 1995, so it seems a recent patent ! i wonder what happen of that discovery
http://quanthomme.free.fr/qhsuite/nouv041005motmagn.htm
http://quanthomme.free.fr/qhsuite/imagnews05/imrismot.jpg
i will search for other links if possible
Drannom
Imris Pavel is a genious
he also get a radiant device !!
Optical Electrostatic Generator  http://www.rexresearch.com/imris/imris.htm
That make the gravito magnetic wheel more interesting, it must be a working wheel !
http://img141.imageshack.us/img141/6228/mouvementperptuelxw3.jpg
in this forum i had suppose to find some eminences to clearly analyse this gravito magnetic wheel, instead of waiting for something not working ! we are the 20 june !! surprise Archer will not work ! i am not surprise at all...
@Drannom;
I think the gravity wheel does run. What's amazing is that I made a wm2d simulation with 8 weights. It didn't run but I attached a motor and tracked a weight. It shows that there's more gain than loss.
It might be very subtle why it doesn't run. Somtimes there only 3 weights on the right side for a brief moment. This might be destructive.
Drannom
Hi Broli
thank you for testing it in your simulation, of course 8 balls will not work, that is a matter of variance, then 100 balls will not work either, only 40 balls give the right variance
put a motor to test the power output is a clever idea !
And i wonder what will be if you run it with 40 balls
and then after try to simulate the Imris Pavel gravito-magnetic device, i suppose that magnets does not fit in the simulation
i am still waiting for some eminence to look at the first picture of this topic and explain why it works or not
i have not found the other link on Imris Pavel ? i saw it...
well he is genious and he deserve some attention for the OU forum
it migth be the simple way to extract gravity !
