The Secret To The Entire Universe - I Want To Tell You All
Started by 0ne, December 03, 2007, 05:49:43 PM
Grumpy
Quote from: 0ne on December 05, 2007, 06:47:33 PM
Gravity is easy to understand, it is JUST MAGNETIC FORCE.
Don't you mean "electrostatic"?
        -Frank Edwards
sm0ky2
no, he means magnetic.
millions of millions of tiny molecular-magnetic forces acting on one another.
0ne
Quote from: 0ne on December 03, 2007, 05:49:43 PM
I would really like the $5,000 prize money from this information I am going to give you all for free, but I totally understand if this information doesn't qualify.
Protons and Electrons carry an "electric" charge. This "electric" charge creates an "electromagnetic" field around it. This basically means protons and electrons are like subatomic miniature monopole sphere magnets. In a car battery, you have a metal substance like Zinc, and you have an acid.  The acid physically takes each proton, and electron out of the metal, and they automatically, instantly travel to the negative and positive terminals of the battery, ready to be used as energy. This same process happens in your digestive system with food!!!!!!!!!!
You see, every element/object in The Entire Universe is FUEL. You just need the right acid to break apart the fuel. The more dense the object being used as fuel is, the more longer that fuel lasts.  If you used a sponge for fuel, obviously a sponge is going to dissolve really fast because it is made mostly of air, not protons and electrons, so it would make a horrible battery fuel. If you used granite however, granite is dense and is full of fuel! You could create battery's that will power objects for YEARS!!!!
There it is folks, I explained 0ne of the most ultimate discovery's humanity will ever see. The world is looking for "alternative fuel sources", when the entire time, all mass, all physical objects, everything, including YOU, is fuel, and nobody knows it!
http://video.google.com/videoplay?docid=5787522280823887082
Natures Secrets LOL!
wattsup
@One
Here goes a try to your question.
If gravity is magnetic force, and if magnetic force has two poles, and if you talk about the Earths' gravity, this would mean one pole is always going towards the center of the Earth from all sides of the Earth and let's call this pro-gravity (or whatever).
So where does the other pole go?
If the other pole exits outwards from the center through the same surface of the Earth, this would make anti-gravity?
Then gravity would be the difference between pro-gravity and anti-gravity or, the difference in the intensity between two magnetic polarities.
If pro-gravity is slightly higher, you fall to Earth.
If pro-gravity is slightly lower, you will rise with the anti-gravity.
If pro-gravity is extremely lower then anti-gravity, you'll rise super fast.
So if you build a device that can block pro-gravity at varying intensities, you would fly using the Earths already existing anti-gravity.
oouthere
0ne,
you have the answers so just show us your free energy machine.....then I'll show you mine.
Rich
