Another Magnet Motor Scam??
Started by hansvonlieven, December 08, 2007, 03:32:50 PM
hansvonlieven
Have a look at this one. No claims are made and a kit is promised.
http://youtube.com/user/tracmag
Hans von Lieven
TheOne
I am pretty sure the ring have batteries, take a closer look, you will see the ring tape move, like coil inside are powered by batteries.
hansvonlieven
Yes, but what is he hiding behind that upright sheet of plywood?
If that ring was the only motive force, why have the sheet there and why keep whatever is behind it hidden, when he shows us the underside making a point there is nothing underneath.
Hans von Lieven
TheOne
one of the video show what behind the sheet and they are nothing so i believe its all embeded in the device
http://youtube.com/watch?v=9L05OOhpOSY
Also check this one, look at the bottom of the screen on the top ring, you will see the tape jump in a circle pattern like a coil, and when you look at all the ring you see this circle pattern in all 90 degree, so i bet between the coil its batteries :)
http://youtube.com/watch?v=pRkgu4bfFfA
z_p_e
Quote from: TheOne on December 08, 2007, 05:06:28 PM
I watched videos 1 through 10 (are there more?) and none showed behind the plywood wall.
Obviously there is an accompanying rotating magnet of some sort on the other side that we can't see, causing the one we do see to rotate. Why have the wall there if he has nothing to hide?
