One of my many pulse motor ideas.
Started by nightlife, December 08, 2007, 11:13:26 PM
nightlife
 Magnetic compression motor by way of using magnets as pistons and a head with electronic coils and one way valves for air inlet and out put.
The coils would require a pulse to repel the magnet at the top of the stroke and then attract on pistons bottom of the stroke. This design is a 2 cylinder design that would use one coils collapsing voltage to power the other and vice versa. When one is at the top of the stroke, the other would be at the bottom of the stroke and vice versa.
Not only would this create compressed air but it should also create horse power.
Please give me some of your thoughts about this idea. I have more that I may be posting later so be nice. LOL
nightlife
I was also thinking that the outside of the cylinders could be wound and used to create electricity.
nightlife
I am also thinking that the compression created could run a generator simular to the one in the link below.
http://www.youtube.com/watch?v=Ktzwr1UjO90
I am also thinking that a larger generator could be powered by the turbine in the above video. The turbine is said to be rotating at 38000 rpm's creating 14 amps at 10.5 volts with the small generator using 7.4 psm at 55 psi.
Ren
sounds good in theory, have you considered how you will deal with friction of piston against cylinder wall? Is piston made of non magnetic material and magnet recessed in head? Magnets are very brittle, and if you want to compress air or anything for that matter you're going to need an airtight seal. Have a look at Tropes in this forum, he is tinkering with a piston style electro magnetic motor.
nightlife
Ren, I was thinking of using copper cylinders with thick copper compression rings. I just read about Tropes idea but the link that was provided didn't work. His idea is based on the attraction which may work but I thought that using both the attraction and repulsion would make it more powerful. I was also thinking that the friction between the rings and the cylinders having the cylinders wired to the windings that would wrap the outside of the cylinders would create enough power to fire the coils or at least aid or supply the source that would.
