Capactors inside the Pyramid.....
Started by Pegasus, December 11, 2007, 08:42:40 AM
Pegasus
@kiwijs
Yes,this is my source.But there was somewere on the Net, a detailed schematic with drawings,also.But seems disappeared....
By the way Idont think that people are not able to replicate this simple device....
Cyrano.
pese
That what Mr Siemens feel on the top of pyramide ...
This is no sensation. Another static electricity charge has the water in the wine, because this was not filled on the pyramid in the bottle. However, Mr Siemens has accepted by mounting the pyramid another static load. This difference forms an unloading spark.
Quite normal phenomenon
Pese
wile_coyote7
 ::) When I first read the description of this device, the first thing that popped into my head was "Wilhelm Reich's Orgone Accumulator". Specifically the alternating layers and then the "wet ground".
I found this:
http://www.orgonics.com/whatisor.htm#anchor131172
In particular, this quote from the article above:
"Accumulating Orgone Energy
Reich found that organic materials attracted and held orgone energy; and metal attracted and then rapidly repelled it. By designing an enclosure, similar to the Faraday cage, lined on the inside with metal and made with alternating layers of organic and inorganic materials, he discovered that atmospheric orgone energy was accumulated and concentrated inside. He called this device an orgone energy accumulator. Within the box-like enclosure, the orgone energy given off by an inside metal wall is attracted to the opposite metal wall which again repels it. This creates an oscillation of the orgone energy particles inside. The layering of organic material with metal creates a higher concentration. He experimentally objectified this discovery by observing that the temperature inside an orgone accumulator was higher than inside a control device or outside air temperature. Also, an electroscope which is a device that can be charged with "static" electricity, discharged more slowly inside of an orgone accumulator than outside. These two experiments confirmed that there was "something different" about the atmosphere inside of an orgone accumulator that didn't conform to standard physics. Through many years of careful, experimental research, Reich was able to define the basic properties of orgone energy: (6)
* it fills all space and is everywhere
* it's mass free and is the primordial, cosmic energy
* it penetrates matter, but at different speeds
* it pulsates and is observable and measurable
* it has a strong affinity and attraction to/by water
* it is accumulated naturally in the living organism by ingesting foods, breathing, and through the skin
* the mutual attraction and excitation of separate orgonotic systems result in the merging, or superimposition, of the systems; and the emergence of a new system
* orgone energy is negatively entropic: highly charged orgone systems attract lesser charged, which Reich described as the orgonotic potential
* orgone energy is excited by secondary energies such as electromagnetism and nuclear energy
* when it is concentrated, orgone energy often has a blue-to-violet color."
I also found this while off on a tangent:
http://www.aetherometry.com/abs-AS2v4.html#abstractAS2-25
"Modified Orgone accumulator (HYBORAC) as drive for low delta T Stirling Engines"
I dunno, it sounds hauntingly like the same thing. I am now trying to research any application of the above device and converting it to electricity.
Just my two cents........
?When the power of love overcomes the love of power, the world will know peace.?
Jimi Hendrix
hansvonlieven
G'day Pegasus,
In your first post you state:
Two copper probes are then inserted into each side of the box, from the top down to the center and running against the outside edges. This fellows' diagram shows one probe coming in from the upper left ending at the bottom center of the box.
This is where the problem lies in a replication. How were these probes inserted, do they touch each metallic layer? Are they insulated from everything inside the box, does one probe touch the innermost metallic layer and the other the outermost and so forth. There seem to be a number of possibilities here. Can you recall how these probes interacted with the "box"?
Hans von Lieven
jeanna
This is going to be too cumbersome to quote the several of you that I need to so here is what comes outta my mind with this talk about caps and pyramids.
The Pyramids strung along the Nile are 2 stroke "ram " pumps. I will find the US patent that describes it and give the number for reference. Ed Kunkel got the patent in 1953. His dream was to save the world by getting pumps like these into large rivers and harnessing the energy. Well we know he died an unhappy man. However his investigations and replications showed the patent officers that the design works. They traveled to his place and granted the patent because he proved it to them!!
The "pulser pump" that Brian White developed is a single stroke pump using similar forces in similar ways.
Basically water drops to a deep level and brings air along with it and the air compresses until it cannot compress anymore then it burps up to a level above the input level because the pipe is thinner in diameter. In the pyramid this happens in the 'well' and  the so called queens chamber. Then by vacuum pressure this water is drawn into the grand gallery . Each cycle the water is drawn higher until it fills the grand gallery with water. Ed Kunkel showed that a small fire in the air above the grand gallery was able to cause this vacuum pressure.
The problem with Kunkel's plan was that there had to be a "fireman" hidden above the kings chamber to do this.
What happens in the grand gallery is that the vacuum is so intense that it is able to pull HHO as a gas out of the liquid water. That ,as we know, is a very flammable gas and a periodic spark is all that is needed to flash the HHO gas and recreate the vacuum to keep the pump running.
So, yes, indeed the pyramid has this ability to create capacitance, as shown by the wine bottle, and all those quartz crystals in the granite being squeezed by the weight of the pyramid structure direct a spark into the Grand gallery right at the top.
Ed Kunkel said he saw a perfect "teardrop" shape of soot at the top ot the grand gallery. He showed this to the Egyptologists to prove his point. When he returned to Egypt he found that the soot had been whitewashed!
We know this is an old story. We see this over and over.
The point is that the pyramid IS AN ELECTRICAL DEVICE. This is the reason that pump was housed within it, to provide the all important spark!
jeanna
