Capactors inside the Pyramid.....
Started by Pegasus, December 11, 2007, 08:42:40 AM
Drannom
Hello
that story of implosing gas was very interesting Jeanna, i have never imagine that level of technlogy
when an implosing gas occur there is no heat,
there is a another story that i will shortly resume to you, it's all about telluric current rushing in the pyramid and reflecte back down rigth by the central axe
positive cosmic ray accumulate in the earth, as negative telluric current
the Cheops pyramid collecte the negative part of those positive cosmic ray
it was called the green-black negative ray, the king chamber was not rigth under the central axis to collect only the positive part of the green-dark negative ray
the tomb was a way for human to be expose to the positive green-dark ray and be transform in a new level of existence (mind supra conductivity)
i may find some links on that, but not sure
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
Drannom
Hello
on the other topic (TT pyramid), someone gave us a fantastic link from David Wilcock,
http://homepages.ihug.co.nz/~sai/torscons.htm
he is the reincarnation of Edgar Cayce !! i have a picture of him and he really look like Edgar Cayce, i will try to attach this picture in that post
so this is an extract when someone successfully charge a capacitor over a pyramid !
TWMCHAPTER NINE: HARNESSING TORSION WAVES AND CONSCIOUSNESS David Wilcock
9.7.6.3 A COLUMN OF ?UNKNOWN ENERGY? APPEARS ABOVE THE PYRAMID In the third of Golod?s experiments, the Joint-stock company ?R&D Institute TTR? conducted studies of the air above the pyramid with a Russian instrument similar to radar known as a ?military locator.? A column of ?unknown energy? was detected at a width of 500 meters and a height of 2000 meters. Further studies confirmed that a larger circle of this energy surrounded the area above the pyramid in a 300-kilometer-wide range, with the highest concentration being directly above the vertical fulcrum of the pyramid. Golod?s team calculated that if such an energy column were to be produced electromagnetically, it would require all the energy of the various power plants in Russia combined. Furthermore, less rigorous was the observation that after the pyramid?s presence was established, an ozone hole that had existed over that area of Russia was seen to repair itself in only two months? time. This column of unseen energy did have other immediate uses and effects as well. Electrical energy from the pyramid could be harnessed by a capacitor that was placed at the apex of the pyramid; the capacitor would spontaneously take on a charge. Furthermore, pieces of the capacitor assembly were seen to break away and rise into the air on the energetic column that the pyramid was producing. It was also discovered that people working near the top of the pyramid might start to experience dizziness and nausea, and need to be taken some distance away from the pyramid for these effects to subside.
i suggest to every one to read the full link it was a very instructive one
i have also read all about Pajak, and his pyramid never worked, for sure it was an imcompleted plan from telepathic communication , so it could not be the Accu - Loader that i am looking for
here a short extract
   Daniela Giordano & Jan Pajak
   "STORY OF ONE PYRAMID"
   Treatise, Dunedin, New Zealand, 1995
   ISBN 0-9597946-5-4
Copyright ? 1995 by Daniela Giordano and Jan Pajak.
   THE DISCLOSURE AND PROTOTYPES
One night around the summer 1978 I was sleeping in my bedroom. Unexpectedly my dream was interrupted. And as it sometimes happens when a film breaks during the projection of a movie, only a big black screen without borders remained in my view.
On this black screen a "Being" appeared, possibly of male gender. Actually "He" was a little bit strange. He had a head quite big and round like a billiard ball. His skin was milky-white and it was possible to see thin, clearly blue and pink capillary vessels on His cutis. The pattern of these vessels reminded me of delicate wrinkles on the facial skin of a prematurely-born baby. The nose was just outlined, the mouth was only a short, horizontal cut on a little chin. But the eyes were big, clear blue in colour, sweet in glance, placed on very high cheekbones. It didn't appear that the skin of His face had ever known a beard. He had no hair at all. The neck was thin but not very long. The thorax, the arms and the hands were white-grey, maybe only a half-tone darker than His head - as if He wore a very thin and tight suit. I don't remember having seen nails or ears.
Between His hands He held a pyramid of about 27.5 [cm] high (see Figure 1). At the outside it was of lacteous colour and looked made of opaque plastic or perspex ("perspex" is the commercial name for a material made of "methyl methacrylate resins"; popularly it is also called "organic glass" or "plexiglass"). The inner space was not visible. With the open palm of His right hand He supported the pyramid's base while the open and tight palm of His left hand rested on the cusp of the pyramid.
He was facing me as in a half-length photograph. He did not seem to be very slim nor fat. Surely you could not define Him as a lean guy. It gave the impression He had never done gym exercise in His life.
He let Himself be watched by me for a moment before beginning to talk. He didn't move the mouth and His words arrived directly to my mind in Italian - as if I have had the ears over there rather than on the sides of my head. When He talked the pyramid emitted an intense and soft white pulsating light following the same rhythm as His words and emotions.
"You must build a pyramid like this one", He said.
"Why?" I replied. (I don't like strangers telling me what I should or shouldn't do.)
"To talk better to each other", He answered.
It looked a good reply. I considered for a moment my 'technical capability' and said: "It is impossible. I am not able to do it. I don't have technical knowledge in my background".
"Don't worry, it is not difficult", He answered with reassuring tune and with the emotion of a smile transpiring between His words.
"Listen to what you have to do", He continued. "Take a phial and fill it half with mercury and half with salt and put them in the vacuum...".
I interrupted Him asking: "What kind of salt?" (I was thinking in my kitchen I had two pots of salt. One with thin salt for dishes and the other one with salt of bigger grains - just called 'kitchen salt' because you put it directly in the water when boiling spaghetti).
"Kitchen salt will be good", He answered. "Then you connect the phial to a spiral and the spiral to a pyramid {frame}, then ...".
I interrupted Him again - now slightly troubled because I had lost the 'thread' of the argument: "It is too difficult!".
This time my interruption came to nothing. He continued unperturbed as if He had not heard me: "... Place quartz inside the spiral over the phial ...".
"But I am not able to!", I repeated.
"... place an aluminium disk on each face of the pyramid. One of them must have a hole in the centre ..."
The more He talked, the more I became troubled. He did not give me the time to think. He provided me with too much new information and I had no time to assimilate everything. Already I almost forget what He had told at the beginning of the speech.
I shouted: "Stop, please, stop!"
"... build a pyramid {frame} and the spiral with copper and connect them together ..."
Now I was really angry. My interruptions were ignored. And if the other person doesn't hear you, it is not a dialogue but an imposition. So I shouted again: "Stop, I don't understand!". But by now He was 'gone'. He looked like He was video-taped: "... when you connect them, remember that all must have a ratio: that one between the pyramid and the spiral must be the same, the quartz and the frequency must be harmonic. Even the inner volume of the pyramid must be in the vacuum ...".
I don't remember what else He said. He continued to talk and talk ... I was no more listening. At that moment all my efforts were concentrated on the attempt to break off that contact. I was aware that a part of my mind was connected with His, but His 'panzer-kamikaze' will (strong will) had really disturbed me. And I wished with all my strengths to come out of that situation.
When I was a kid I had found out that to interrupt a bad dream or a nightmare it was enough to get angry with the character of the dream, or with the situation, or with myself. It worked also this time and I woke up still breathless and with my heart beating wildly. I found myself in my bedroom and it was still night.
Pegasus
http://www.youtube.com/watch?v=MhVIXfNGJ58&feature=channel
I have found this video showing a guy with pyramid/capacitor generating some electricity....
I missed the part in the video where he actually shows a pyramid/capacitor generating some electricity...
But here's another video by the same guy.
Even more interesting, don't you think?
http://www.youtube.com/watch?v=SBnFQ8cMySs&feature=related
sparks
   This rock inside two differential models and the glue look alot like a planet.
Something like a gravity splitter.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
