"Self Running 900 Watt Fuelless Electrical Generator" Is this new?
Started by bourne, December 16, 2007, 11:07:06 AM
vidbid
After studying the operation of Bruce DePalma's Sunburst Generator which doesn't produce any drag and is clearly overunity, at least, to me, it seems that this Witts' self-running generator is based on the same principle. I believe the Witts generator produces DC. I believe all of the magnets in the rotor face outward with the same polarity. I believe the inner part of winding only comes in contact with the B-field, and the outer part of the winding DOESN'T come into contact with the B-field, so no voltage is induced across the outer part of the winding. Only the inner part of the winding has a voltage induced across it, and that is a DC voltage. There may be some sort of ferrite material in the center of the stator core to prevent the B-field from reaching the outer part of the winding. As for the capacitor bank, I believe that it only stores the charge received from the inner part of the winding, probably around 60 to 100 VDC. The DC voltage is then fed into an inverter circuit, and from there to the 120 VAC load. There may be a resonance component to the generator, but I don't believe that it is necessary.
Another difference is Bruce DePalma's Sunburst Generator doesn't require a stator. The magnet and disk which are rotating as one constitute the rotor and stator. The main thing is the rotating homopolar B-field cuts the plane of the copper disk at 90 degrees.
I believe the Witts self-running is another homopolar generator however with a specially wire-wound stator and a homopolar B-field magnet rotor. The geometry of the Witts device produces a significant voltage because of the inner winding. The voltages induced across the parallel segments of the inner part of the winding are additive.
This device should be relatively simple to build.
There is no such thing as a "Witts self running generator" or any other OU device from Witts. That whole operation is a scam and their video demonstrations of their devices are fakes.
If you don't believe me, then please, by all means, send them the money they are asking for, get the "plans" and build one of their miracle machines yourself. What they are asking in terms of money is ridiculously cheap-- if they actually had what they claim to have.
But they don't.
e2matrix
Quote from: e2matrix on January 25, 2013, 12:31:24 PM
http://search.4shared.com/postDownload/xGnHQa0i/flux-switched-transformer-10a.html
That will get you the document on the flux switched transformer and also it has links to Naudins work on it.
Don't try the above link anymore as it is now just malware (pdf.exe) as well as clicking that link will put another malware or virus on your computer.
So vidbid if you think it's easy to build then build it!   When was the last time you built anything?   TK is right on this.  I think Witt's is just a major scam hiding under the guise of a religion.   At least if they do have anything that works they are keeping it a very well guarded secret but IMO they have nothing of interest.
vidbid
No one ever built a statue to a critic. ―Emil Rhodes
To avoid criticism, do nothing, say nothing, be nothing. ―Elbert Hubbard
New opinions are always suspected, and usually opposed, without any other reason but because they are not already common. ―John Locke
Whatever you do you need courage. Whatever course you decide upon, there will always be someone to tell you that you are wrong. ―Ralph Waldo Emerson
Quote from: vidbid on February 05, 2014, 02:45:01 PM
Great! I guess this collection of quotes means you are going to send Witts some money, and build one of their devices for yourself! Great! We will be looking forward to your reports.
(By the way, it is not true that there are no statues of critics; a google search turned up hundreds of them. Neither is it true that you can remain silent to avoid criticism. And there are many good reasons that _certain_ "new ideas" are opposed, not just that they are not common. Furthermore.... I hope fervently that there will always be someone to tell you that you are wrong, when you are wrong. You can be as courageous as you like, but if you step on a land mine.... you are wrong and you had better hope that someone tells you about it before you take that courageous step.)
