Thanks to ALL for your help!!
I have a working shuman resonance circuit for sale
Started by magnetman777, December 16, 2007, 04:13:21 PM
Bruce_TPU
@ All
I have spoken via phone with magnetman and he indeed has a circuit to receive the Shumann's Resonance.  (A receiver)  This is picked up as a sine wave and amplified.  This can be seen on your scope.  Magnetman wanted to see if it was a "real" thing himself, and he built the circuit.  He has also placed this onto his controller.
He desires to sell the circuit to help further his TPU research.  There are some HV transformers he needs, etc... adding up to hundreds more dollars.  So that is his only reason for selling the circuit and not giving it away.  I can tell you that the circuit is legit.  What you do with it, or how you experiment with it, is of course up to you.
I also learned more detail about the vibrating coil and magnet.  It ONLY VIBRATES IF THERE IS PLASTIC BETWEEN THE MAGNET AND COIL!!!!  He discovered this by accident.  Without the plastic the magnets just stick.  With the plastic washer, between the magnet and coil, when resonance is reached, full vibration begins.  I think this is a SIGNIFICANT FIND!!.
Magnetman also has a patent #6194978.  So he does know his stuff.  His contributions will be helpful to everyone.
Holiday Cheers,
Bruce
hartiberlin
Hi Magnetman777,
congratulations.
If you don?t want to win theOverUnity Prize
and make it open source,
please at least show us some
proof of your working device.
Many thanks.
Regards, Stefan.
magnetman777
Hi all I will try and make a video and post it . I am not sure how to change my cam corder into a smaller compressed video but i can make an avi. I ll try and post it .The receiver I made has a fet for the front end and several filter stages. i am going to make a DSP circuit for . If you use the circuit and the XY of your scope you will be able to see the Lissajous pattern at roughly 8 Hz .this will vary on the accuracy of your generator .I have a digital generator and the freq says 7.8 Hz .
Starcruiser I am not using a toriod in the receiver
Thanks MM
Super God
What can you do with this incredibly low frequency?  Do you think there's usable power there?  Maybe you could transmit something a really really long distance!  Like power?  Ooo it's worth a try!
>9000
Bruce_TPU
Quote from: Super God on December 16, 2007, 10:00:26 PM
@ SG
That is actually a good question.  MM and I also discussed this.  We came up with a couple of good experiments.
1.  Make resonance of coil to match receiver, and then over ride with VHF
2.  MM explained that RF band carriers when 'interrupted' produce spikes of power.  (Kicks!)  So things are done to either keep that from happening or filtering it out.  Now, I remember SM saying that, "So many things go by that are seen, and no one stops to ask, why?"
Well I asked, why the spikes, and can something be done with those spikes/kicks if you had enough of them fast send off?  I also asked what if he 'interrupted' the received signal from the Shuman's would there be a spike?  MM replied, "Yes, and it is much easier to 'interrupt' the signal at VLF, just a few transistors.  Interrupt it enough times per second, to produce those kicks and you have "perhaps" some usable power.  MM agreed to experiment with this line of thought, also.
Holiday Cheers,   ;D
Bruce
