Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
hartiberlin
Test.
There are unfortunately a few posts lost as there was some kind of bug,
so one could not post on page 19 of this thread.
Please repost your postings, which are now deleted.
Many thanks.
turbo
Quote from: hartiberlin on January 21, 2008, 10:23:27 AM
Test.
NO , my time here is OVER!!!!
Happy crushing database erorr site report to your freaking admin everybody!!!!
Ciao.
hartiberlin
Hi Marco,
this is probably an error that is related to the forum software still having a few bugs.
Also I did not yet find a solution to this error,also not yet at the SMF forum programmer website. Regards, Stefan.
otto
Hello all,
my last post dissapeared. I will try to explain again what Im doing.
I wound a 9 turns collector with lamp wire. Dimensions well known: inner diameter 4", outer diameter 6".
I looked at my coil and got an idea: why not try to pulse just 1 strand of my lamp wire and on the other strand to connect a 100W bulb. So I did it.
On 1 strand the pulses and the +12V from the power supply and on the other strand a bulb and in paralel a 47nF/1kV capacitor. Without any control coils!!
I used just 1 frequency. The highest frequency range from my oscillator = 100 - 300kHz.
At the frequency of 245kHz I had a "success". I saw little sinuses forming from the kicks and then I saw the voltage/current rising. Of course, the light was getting better and better. A just little move of my frequency and the voltage rised to 40 - 60V and the current to 2 - 4A. At this values the bulb lighted at 100W. I also had a vibration of the signals on my scope at 5 - 10 Hz.
Then, yesterday I builded another 9 turn coil, the same as described and connected this 2 coils together.
As I have only 2 MOSFETs (others blown), I pulsed 1 coil with 1 frequency (range 1 - 10kHz) and the other coil with the frequency range 10 - 100kHz.
At some point I got the same "success". This time only the current rised to an unknown level but the voltage was stable = 12V. I didnt had the well known vibration of 5 - 10 Hz this time.
As I lost in the last few months a lot of MOSFETs ( over 50, no typo!!) I decided finally to build TUBE OSCILLATORS because I see NO CHANCE to continue in my research.
My power supply for the TUBES is reday.
Otto
Earl
Quote from: otto on January 22, 2008, 07:57:25 AM
Otto
Otto, I do not understand "connected together" ?
Do you mean physically next to each other - or do you mean a galvanic connection ?
I think you have two 2-conductor wire coils of 9 turns each.
  • On 1 conductor of coil 1, you have +12V pulsed with FET at f1.
  • On 1 conductor of coil 2, you have +12V pulsed with FET at f2.
You have 2 output coils, independent and no galvanic connection.
It would be possible to connect these two output coils in parallel or in series - or leave them independent.
Do these two output coils have the same scope signal - or - do they have different waveforms?
Is this simply a HF transformer converting primary energy to secondary energy ?  Or is there something special with this configuration?
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
