HERE IS YOUR FREE ENERGY. HANDLE WITH CARE.
Started by 0ne, December 19, 2007, 06:23:49 PM
Localjoe
@Night life
            sometimes less chatter is better.... I was asking if anyone acctually knew how the process worked and what factors went into it.. not that freakin freq created everything....    I have a valid point in saying if we knew what factors and variables affect the receptivity range of a crystal  or crystilane substance.  So now .. im going to try what you said. I have glass with salt here and im going to sing to it.  Constant tone of a 440 and if your right i should have a resonate crystal tuned to a440 in no time. :o
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
argona369
Your right.
But what about tuning into an atom?
Duality states that matter is a particle and a wave.
Look up electron waves (quantum not phonon).
Here?s some nice photo?s of electron orbitals.
http://web.archive.org/web/20021201193734/http://clasdean.la.asu.edu/news/images/cuprite/
http://hyperphysics.phy-astr.gsu.edu/hbase/ewav.html
http://www.britannica.com/eb/article-77520/quantum-mechanics
Or maybe right down to quantum foam? But how could you transfer that energy? And is it possible to ?drain? an elementary particle.
http://en.wikipedia.org/wiki/Virtual_particle
Or maybe the reverse of this?
http://en.wikipedia.org/wiki/Pair_production
Cliff,
Quote from: Crane on December 19, 2007, 08:13:41 PM
   The size of an antenna is proportional to it's wavelength. Ultra long waves needs very large antennas while shorter waves needs smaller antennas. The shorter waves in use these days, if I'm not mistaken, are high definition radar, in the order of 1 cm... You can always try to build very tiny antennas for the far infrared but I doubt you can do something useful since no diodes can't operate at their frequencies. :(
   To get energy from visible light I suggest solar cells. Simple and easy, and more effective than before, thanks to technological advances.
   X-rays and cosmic rays are powerful, yes, but they aren't very powerful on earth. Luckily, since they are a health hazard... No way to get usable enery from these AFAIK.
A.A.
wattsup
@One
I think you are very right about the Crystal Radio. Funny I had been researching this since a few weeks now and had put some links here and there on the board. Coincidence or drawing from the universal knowledge?
There was an artcile I had found that stated during WWII that they would make rudimentary crystal radios since they could hear broadcasts without using an outside power source. The radio receiver powered the radio.
One of the reasons I had researched this was to see if such a device can be used in a loop with the sound and receiver creating a feedback loop thus feeding on itself.
There are some fantastic web sites on these radios that go way back. Real works of art.
hansvonlieven
Crystal detectors do not need a power source. You need a fairly good antenna though or they will not work. I built my first crystal detector in the early 50's. the rectifier was a galena crystal that was touched by a thin "whisker" made from very fine silver wire. You had to find a good spot on the crystal. The antenna was 30 m long and was strung between the house and a tree, about 10 m above ground. The headset was a high impedance magnetic headset as they were common around that era. Today you would use a germanium diode instead of a galena crystal
Reception was surprisingly good, especially at night.
Hans von Lieven
pese
Quote from: 0ne on December 19, 2007, 06:23:49 PM
A cyrstal radio can collect radio waves with no external power needed. Only the power from the radio signal is used.
http://en.wikipedia.org/wiki/Crystal_radio
Radio Waves are just "electromagnetic radiation" at a certain frequency. When that frequency is raised or lowered, it is no longer classified as radio waves, even though it is still the same force.
http://en.wikipedia.org/wiki/Electromagnetic_radiation
This means, a cyrstal radio is a free energy device taping into FREE ELECTROMAGNETIC RADIATION.
Modify the tuning coil of your radio, and you can pick up ALL OTHER ELECTROMAGNETIC RADIATION including microwaves, terahertz radiation, infrared radiation, visible light, ultraviolet radiation, X-rays and gamma rays.
If you can capture radio waves with an antenna and a coil, then you can capture microwaves, terahertz radiation, infrared radiaiton, visible light, ultraviolet radiation, x-rays and gamma rays that same exact way because ALL of those forces are the same thing! The only difference is the frequency.
Teslas free energy reciever was basicly a simple radio. Instead of a speaker, he used a motor!
D.K.S.
Crystal radio
(detector-receiver  IS NOT an FREE ENERGY DEVICE.
You can only receive the signal in the power-straing (on headphone) in this mW or microWatts strengh as the radiation of the station give POWER to you.
I have lived directly below an MW transmitter, the strength was so strong
(near the transmitter that also a small lamp instead of the earphone in time of the modulation burnt.
im 1 km distance , not nor the lamp burning , but receiving very stron , with Shot" antenna.
THESE IS NOT FREE ENGERIE.
It is a "tapped" energy
Pese
It is "stolen energy" , if you use this to drive your lamps , so wat doing the people in BERLIN
(before WW2) under the Deutschandfunk-Long-Wave Station)
Each wat , that go from Antennas to Bulb-Illumiation , will not got
in the air (ocer the word) ! SO it is stolen AND NOT FREE.
My experimiments with crystal setsstart nearby 60 year ago
and the start for my profession.
@JackH
Jes , Right.
The youg people have not work with-it,
So they cant know it.
The older one... :
I belive only one from 500 can explain me
Gustav
