Bring Electicity from H2O
Started by mxx, April 04, 2005, 03:01:18 AM
0 Members and 119 Guests are viewing this topic.
rlm555339
Quote from: psyd on April 21, 2005, 01:54:03 AM
yes I do , but like all things this was years of research to discover.
But boy does it increase the ratios of gas produced to unit of energy taken up in it
- - - - so then it's a secret formula?
Ronald Classen, 30+ years electrical tech
gfcgamer
Stefan, about changing spark time - forget, you will not need..... See this:http://www.nexusmagazine.com/articles/Firestorm.html
OK! LETS MAKE IT!
Quote from: hartiberlin on April 07, 2005, 08:23:55 PM
I see, thanks for the info.
Well, maybe try to run the H2 + O2 mix with air in a ratio of about
30:1 air: H2 +O2
This means much more air than oxyhydrogen gas !
Then you also get a slower bruning of the gas and
it will not damage your cylinders due to detonation.
ALso you have to change the sparking timing of the sparkplugs
to get the right timing of the spark occurence at the right shortly
after TDC...
Good luck and please keep us informed about your progress.
Regards, Stefan.
DADINK
WolfRAM
Sorry to tell you guys but, acetone is not a good polar molecule as water is,
you'll end up having vinegar... mouahahahahah!
