Muller Dynamo
0 Members and 40 Guests are viewing this topic.
SkyWatcher123
Hi romerouk, nice work on the generator. It seems as though you're using principals from your 'overunity 2' video. http://www.youtube.com/watch?v=9lYTr16vdOM
And on top of that you're using the odd/even setup like Muller, good ideas.
So with the example of your video 'overunity 2', where you show 2 magnets at opposite end repulsively interacting and nullifying that repulsion by using the ferro core attraction at the coil/core.
It seems possible one can get extra shaft power from that alone, though the odd/even is probably an extra bonus.
I'm going to test the principles in the 'overunity 2' video, i have everything here from other projects to easily replicate it. Was that coil intended to be pulsed or is it driven by a separate motor.
peace love light
romerouk
Quote from: SkyWatcher123 on May 04, 2011, 05:51:09 AM
peace love light
Hi,
That setup can be used in both configurations, having a coil to drive it or with a motor attached to the shaft.Testing must be done with the load connected then adjust the magnets
romerouk
Quote from: gyulasun on May 04, 2011, 05:08:54 AM
Hi Romero,
CONGRATULATIONS!  You seem to have a COP=2 setup!  Very good.
For any naysayers a possible looping should be practical by using a DC/DC converter, such off the shelf units have at least a COP of 0.8 i.e. a 80% efficiency (or higher), this means the resultant COP still remains around 1.6 (0.8*2) and because you showed 12V output at 2A current (24Watt) the remaining available extra power (beyond the output taken for selfrunning) is at least 5-6Watt:
you can win the overunity price right now!
Here is a possible DC/DC converter I think would be good for looping back your output to input:
http://www.powerstream.com/dc6.htm
Of course there should be many other products like this or you can surely build a simple one from switch mode integrated circuits. The requirement is the converter should have a regulated 12V output voltage to prevent run away situation.
rgds,  Gyula
Hi Gyula,
good ideea to use a DC to DC converter. Ofcourse I have tried to self loop starting with the battery to get up the speed then disconectig and leaving a 47000uf/40v capacitor.That almost destroyed my driving coils, they are melted a bit but still working.With the battery connected and the bulb in parallel it works good and charging the battery too.I did't think of a DC converter but now I realise that I must have one. I will order one and see the results... as for the overunity price we shall get the most of this setup then look for it. I think that a solid state device (no moving parts)  will win that price, it is what everyone is looking for.
Best regards,
RomeroUK
penno64
Hi Romero,
May I ask, what provides the trigger for the drive coils, please?
Penno
romerouk
Quote from: penno64 on May 04, 2011, 07:32:55 AM
Hi Romero,
Penno
hall effect sensor
