Muller Dynamo
0 Members and 155 Guests are viewing this topic.
conradelektro
Strange video on a Romanian web site:
Looking around for Muller Dynamo replications I found a strange video claiming a self-runner with a DC-motor (output from generator coils drives DC motor). Only coils on one side of the disk carrying the magnets. The speaker claims the coils are taken from relays.
http://freeenergylt.narod2.ru/muller_dynamo/     Look at the fifth video from the top down, at minute 4:30. The contraption is hanging on a thin thread in the air and the speaker claims it is self-running.
I also found the video on YouTube :
http://www.youtube.com/watch?v=POqJQzjMIZc&feature=player_embedded
http://www.youtube.com/user/Rod5157#p/u/18/xbF63Gzvtd4
I do not know anything about it, all attempts to find the details promised in the video failed.
Greetings, Conrad
nul-points
Quote from: duff on May 12, 2011, 10:58:42 PM
Audio Spectrum  Analysis of RomeroUK "Suspended In Air" Video
(first 20 seconds of sound)
hi duff
looks like your data from the 'suspended in air' video ties in with the 'slowest/lowest freq' component (~190Hz) i saw in the spectral data from the 'self-run' video, possibly magnetic events, so 8x or 9x the rotor rpm
  link --> http://www.overunity.com/index.php?topic=3842.msg286040#msg286040
it looks like member 'tanakat' was trying to point out about the variation of the scope shot peaks as the trace crosses the scope
this is likely to be the modulating effect of 50 Hz utility power pickup by the unshielded coils on the device - so the trace width period will be a reasonable proportion of 20ms...
a trace width probably less than 5ms - because it's less than 1 half-cycle (10ms) and also it hasn't yet passed the peak halfway thro the 10ms
if that was true, then the timebase would be 0.5ms or less
however, if Romero's scope trace shows a close relation to the ~190Hz audio signal then each full +/- pulse cycle shown will be approx 5.25ms - they take about 2 major divisions on the scope axis which would put the nearest scope timebase at 2ms
so - somethings out very approximately by a factor of 5 or more
if it was out by a factor of 8 then the 190Hz signal doesn't represent a magnet/core event
we need to get some early feed back from replicators who are in a position to get us some scope shots from their Gen coil test setups!
cheers
np
http://docsfreelunch.blogspot.com
bluesky
conradelektro
Quote from: bluesky on May 13, 2011, 01:45:36 PM
This was done by Rod5157
http://www.youtube.com/watch?v=AWpB3peU3Uk
Back in 2008
In this video one sees batteries at the back of the motor. Obviously he is using one set of batteries to charge the other set. May be that is always the case with this replication. That would not be very exciting.
I found this web site from the builder: http://rod45103.tripod.com/index.html  (He needs a job. It seems to be difficult to become rich from a self-runner.)
An other video by the builder: http://www.youtube.com/user/Rod5157#p/u/2/SOyPEiPb9Zw (he was looking for investors back in 2009)
Greetings, Conrad
redrichie
If we were to think of this in terms of the Leedskalnin device. With the PMH being a U shaped magnet.  The fly wheel has  a N and S per "V".  If the N of the Vee were coming around to the north of the PMH a south would be about to interact with the south of the PMH, and a reverse polarity pulse was supplied to negate the poles then the inertia from the large flywheel would start to carry it through the normal magnetic attraction to the core of the PMH, just enough for the pulse to stop and release the negated poles and repel the N/S sides of the V magnet.  The fly wheel would then continue to carry it to the opposite poles of the PMH and attract them in.  Again a pulse is supplied to negate the poles and let the flywheel move through the magnetic field.
     ED also described how to make the perfect generator coil.  A coil with a core with a metal pipe on the outside bonded together by a metal cap.  Right next to the flywheel is a pipe with a flange that could fit a cap. On his tool board is a long coil that will fit right down into that pipe.  A perfect generating coil.
