Muller Dynamo
0 Members and 202 Guests are viewing this topic.
neptune
@Conradelectro .This video is disappointing in that no measurements are shown . He does say something about needing regulation to prevent the charged battery overcharging . He talks about  a version that automatically swaps the batteries  but does not discuss run times . It would be very interesting if it could only self sustain without a load . The design looks very simple , and uses an off the shelf motor of not very high efficiency . No mention of stator magnets . Not enough info to draw definite conclusions . I am left wondering if it would self run with a DC-DC converter .
plengo
Quote from: redrichie on May 13, 2011, 02:08:40 PM
If we were to think of this in terms of the Leedskalnin device. With the PMH being a U shaped magnet.  The fly wheel has  a N and S per "V".  If the N of the Vee were coming around to the north of the PMH a south would be about to interact with the south of the PMH, and a reverse polarity pulse was supplied to negate the poles then the inertia from the large flywheel would start to carry it through the normal magnetic attraction to the core of the PMH, just enough for the pulse to stop and release the negated poles and repel the N/S sides of the V magnet.  The fly wheel would then continue to carry it to the opposite poles of the PMH and attract them in.  Again a pulse is supplied to negate the poles and let the flywheel move through the magnetic field.
     ED also described how to make the perfect generator coil.  A coil with a core with a metal pipe on the outside bonded together by a metal cap.  Right next to the flywheel is a pipe with a flange that could fit a cap. On his tool board is a long coil that will fit right down into that pipe.  A perfect generating coil.
very clever. It totally makes sense. It  is a perfect mechanism to make the whole rotor become out of balance when he triggers the coil and helps the rotor to spin more seeking for balance again. It kind of fits what I described on my other thread ( http://www.overunity.com/index.php?topic=10716.msg286049#msg286049).
Fausto.
neptune
If we look at Romero`s reply number 122 page 9 , he tells us that he started making OU generators from model aircraft motors . He states that it is very easy to make an OU generator from such a motor . He talks about rewinding the motor , but no mention of changing the magnet arrangements . He does not give us info on the new winding arrangements . These are very high RPM motors , and if you want to operate it as a generator at lower RPM , you would use thinner wire and more turns . Does  anybody know of a larger motor of this type [3 phase permanent magnet] ? Notice that there is no mention of using opposing stater magnets , [Muller style] nor IMO would it be possible .So he is saying indirectly that an overunity Generator is possible without this trick . He gives us not quite enough info to try it .
Romero , Romero , wherefore art thou Romero...
toranarod
toranarod
Quote from: nul-points on May 13, 2011, 01:43:45 PM
hi duff
looks like your data from the 'suspended in air' video ties in with the 'slowest/lowest freq' component (~190Hz) i saw in the spectral data from the 'self-run' video, possibly magnetic events, so 8x or 9x the rotor rpm
  link --> http://www.overunity.com/index.php?topic=3842.msg286040#msg286040
it looks like member 'tanakat' was trying to point out about the variation of the scope shot peaks as the trace crosses the scope
this is likely to be the modulating effect of 50 Hz utility power pickup by the unshielded coils on the device - so the trace width period will be a reasonable proportion of 20ms...
a trace width probably less than 5ms - because it's less than 1 half-cycle (10ms) and also it hasn't yet passed the peak halfway thro the 10ms
if that was true, then the timebase would be 0.5ms or less
however, if Romero's scope trace shows a close relation to the ~190Hz audio signal then each full +/- pulse cycle shown will be approx 5.25ms - they take about 2 major divisions on the scope axis which would put the nearest scope timebase at 2ms
so - somethings out very approximately by a factor of 5 or more
if it was out by a factor of 8 then the 190Hz signal doesn't represent a magnet/core event
we need to get some early feed back from replicators who are in a position to get us some scope shots from their Gen coil test setups!
cheers
np
http://docsfreelunch.blogspot.com
The neo magnet on the back of the ferrite core is very important we can see why he used them now. Once again it was too complicated to be a hoax.
The polarity of the magnet can increase motor speed and out put amplitude or decrease output amplitude. Dependent on magnet pole
As with all pulse motor design timing is every thing. The only thing that concerns me is the output voltage amplitude the CRO is set on 2 volt divisions. This will double when both coils are in series but I don’t know at this stage how it got to 12 volts. I still think he had the DC to DC converter for a good reason.
