Muller Dynamo
e2matrix
As always way nice work Clanzer!  Do I see individual switches mounted for each coil set?  Purpose?
CLaNZeR
Quote from: e2matrix on May 22, 2011, 03:11:33 PM
Yep one switch per coil on the bottom plate and on the top plate there is one for each of the driving coils.
They are there to simply allow me to switch polarity on each coil pair and also if I want to switch the setup from attraction to repulsion I can flick a couple of switches instead of re-wiring it.
Cheers
Sean.
http://www.overunity.org.uk
Scorch
Two notes on construction:
#1
It has been my experience that typical ball bearings are not designed for thrust loads.
By building your replication to sit flat on a table (vertical axis) as RomeroUK did, you are asking your bearings to operate in a thrust configuration.
You will discover an increased RPM by simply operating as a horizontal axis as opposed to vertical.
#2
ZeroFossilFuel is correct in stating there is an inherent DANGER in building and operating a high RPM rotor disk.
I plan to use phenolic board for my rotor but I'm finding many sources are very PROUD of their phenolic products.
Then I discovered a wood working site that has 1/2" X 11" X 15" phenolic boards for only $23 each.
See:  http://www.highlandwoodworking.com/phenolicboard12x11x15.aspx
Hope this helps.
Please work safely.
Scorch.
CLaNZeR
Thought I would share this video that RomeroUK sent me before the Muller Replication.
He managed to get motors to speed up before when applying a load, but the Muller Design enabled it to go to the next level and be self sustaining.
http://www.youtube.com/watch?v=mEaY17NeK_I&feature=channel_video_title
Do not ask me too much on this setup, but it uses the same circuit and same feedback circuit for harvesting the output of the PU.
The core in this pickup coil is MU-Metal.
Cheers
Sean
FreeEnergyInfo
Quote from: CLaNZeR on May 22, 2011, 03:32:31 PM
Cheers
Sean
THANKS.....
