Muller Dynamo
0 Members and 93 Guests are viewing this topic.
toranarod
Quote from: CLaNZeR on May 29, 2011, 07:10:59 PM
Video Part 1
More tomorrow
http://www.youtube.com/watch?v=mcL-EeIeG6s&feature=channel_video_title
hello CLaNZer
very nice Video
I am really looking forward to your results
you are still using the 120 turn coils. I would like to know what there voltage out put will be.
Can you get an inductance reading of the coils with in the magnetic field and out side the magnetic  field
are you going to wind coils to 300 turns 7 x .125 I measure an inductance of .9 mH  on the ones I have wound
I was able to get the out put voltage to 160 volts today by adding a capacitor of the correct value to create an LC tank circuit. this was interesting because
as you know the resonance changes as the magnets pass the coil.
What ever you max RPM is I would like to know your frequency out put. I understand this can already be determined but I would like to see what you come up with. I have observed an anomaly with this.
One more question in all your experience Have you ever seen OU in person in front of you?
I ask this of many inventors who have built lots of devices. most of the time I never get an answer.
Cheers
OH yes the soldering I was over that.LOL
toranarod
Quote from: kEhYo77 on May 30, 2011, 03:55:01 AM
Hi. I'm on this as well, I'm just a little short of money for the components so it goes slow. I would like to put some thoughts on the matter.
From what I know RomeroUK had been working for a while with coil shorting and in my opinion it is somehow incorporated in his design.
From recent disclosure of Ismael Aviso coil shorting technique as the main overunity factor I think it must be true and if not, some of You builders must try this.
So the generator coils should be 'open circuits' until a magnet reaches TDC, then you short the coil for a fraction of second and you open it again and then collect BEMF.  The coils should be wound bifilar, in series (Tesla) because such winding has much bigger energy capacity in comparison to a standard coil. In coil shorting it will be far superior as it is in a sense a coilpacitor of sorts. So for those of you using Litz wire it is just a matter of doing some soldering and proper timing.
I think Romero might be using those tiny magnets for timing of this process...
http://www.youtube.com/watch?v=mEaY17NeK_I
This is important information. I have observed this.
thank for your Post  How do you know this is correct? have you tried to test this?
neptune
@Toranarad . If you have not already done so , read the first 4 pages of the thread "Shorting coil gives back more power " by Romerouk .
mondrasek
Rotor disk and magnet thickness:
The rotor disk that RomeroUK used was made up of (4) disks that were each 3mm thick.  So the total thickness was 12mm.  (Please note that in a clarifying post RomeroUK got his units of cm and mm mixed up a bit.)
RomeroUK originally stated that the rotor magnets were 10mm thick.  But this did not appear to be correct per the videos since we can see that the magnets are thicker than the rotor disk.  When asked about this discrepancy, I believe RomeroUK said something about maybe he had added some 5mm thick magnets that he also had on hand (he couldn't exactly remember).  I believe that he did double up magnets and the correct thickness of the rotor magnets is 15mm:  (1) 10mm thick magnet + (1) 5mm thick magnet. Or maybe even (3) 5mm thick magnets.
While this difference is small in dimensions and may not change the magnetic field strengths much at all, it would have a huge affect in the mass and therefore rotational inertia of the spinning rotor.
The replication documents say the magnets are only 10mm thick.
FWIW.
JouleSeeker
Quote from: nexuses on May 30, 2011, 01:17:22 AM
Greetings from an interested onlooker!
A acquaintance of mine is a very experienced electrical engineer with a broad knowledge in many other areas including physics. If I point him at unusual material on the internet that challenges his views of the universe, I usually get back short blunt "explanations". He always, however, remains open to the possibilities and would be happy to be off petroleum! So I keep sending them.
I sent him romeroUK's videos, pdf and the article written Sterling Allen and Hank Mills.
This was his reply, a distinct improvement from the usual..
"If this works I suspect that it's not 'free' energy.... I suspect that it's working from the earth's motion (Coriolis effect) somehow. Meaning that if lots of people made these things, it would start to slow the earth's rotation. Not sure I'd want to be responsible for that! Someone should do the physics.
{snip}.
If the replications go well (and we all hope they do) then at some point
"somebody should do the physics". That will definitely help the up-scaling process.
That is what comes next.
Nex
Greetings, nexus.  Perhaps I can help in doing the physics, since I'm an Emeritus Professor of Physics myself! with publications in Scientific American, Nature, Physical Review Letters, etc.
http://www.physics.byu.edu/research/energy/  is my web site.
Not trying to brag, at all-- I have a lot to be humble about  ;)   I agree with you and your friend regarding the next step "do the physics"!
I would very much like to contribute to the physics understanding, once a device is demonstrated. Understanding the physics should indeed help in "scaling up" and I share in these goals.
I also offer to help with power/energy measurements, as needed.  I retired early and I'm very interested in freedom energy.  Some comments regarding "Dark Energy" later...
--Dr. Steven Jones
