Muller Dynamo
resonanceman
Quote from: kEhYo77 on May 31, 2011, 10:10:35 PM
Resonanceman, The video DID show those extra parts for coil shorting hanging under the table... @ 3:16...
kEhYo77
Sense you say that the stuff in your picture are the extra parts for coil shorting ...... identify each part  and explain how they work.
ALSO  explain how he hid these parts in the videp with his motor hanging by a string.........
gary
kEhYo77
Resonanceman, the parts are visible only in this coil shorting video. The Muller videos don't seem to indicate using this technique though.
There must be some low Rds mosfet or two in this circuit, a mosfet driver and a buffer cap for driving the gates an a recovery diode, it looks much like that...
TEKTRON
Quote from: kEhYo77 on May 31, 2011, 11:08:55 PM
I agree, looks like a mosfet on a heat sink and a cap. the wires go to hall sensor and coil he was shorting manually.
minoly
I thought Romero's rotor is NSNS "we're" just not seeing what is hidden in plain view. This is how SSG genny coil puts out AC...
http://www.youtube.com/watch?v=l3vrtnawZv4
Looking at Romero's rotor, it looks as though the "invisible" south's conjoin interferometerly.
also, on Romero's build, one coil is on N and the other is on S. didn't I read there is a near perfect SIN wave at the output there on someones scope?
chessnyt
Quote from: toranarod on May 31, 2011, 06:53:52 PM
Hello all
I have many measurements watts current
I will share all measurement. I need some time to put them into a comprehensive format.
I have run the motor on 1 coil and 2 coils. On 50 volts, 12 volts 24 volts.
collected back emf. tried PWM timing, tried diffident coils may types of magnets on top under neath.
have seen some amazing results watched it do things I did not expect. I will make a video very soon.
after watching  CLaNZeR video I could see the RPM and Currents and volts. It was a very similar sight.  The High currents at those voltages are a worry.
if output can pass input it doesn't matter.
It has something to do with phase shift under load. I moved the phase by few  degrease by adding capacitance. this increase the output voltage by 35%
but the timing is still an issue I need to construct more electronics to run more test on this subject.  I think pulling current out at this right moment will
be an interesting experiment.
the other point is there are still many test to do and configurations to try. its not over by any means. I work on.
I would like to hear from others with there results. Not theory and conjecturer black and white
recoded information.
Rod
Nice work, Rod.  Thank you for sharing your results with all of us.  This is becoming a very nice collected effort.  I look forward to seeing your hard data which you are assembling currently for release.  I'm very glad to see so many doers as you are listed among the many here on Stefan's forum.
Outstanding effort!
Chess
