Muller Dynamo
Magluvin
I just watched again at lunch here, I dont see the cap.
The cap should help in providing more power to the load(variable resistor).
Mags
konehead
Just wateched Woopy's video.
Maybe those magnets at backs of cores do nothign as-is or even make things worse?
Seems like the strength and distance of those magnets to function how they are supposed to; (flipping the polarity of the core's poles right when the rotor magnet is starting to pass by so the rotor magnet gets a push, not a "pull-back" that rotationsl-lenzlug would provide)
The "regauaging" magnet's strength and distance is very particular to the rpms, and the particular load on the coils too...too much strength and its like putting in opposing magnetic flux that will make rotor spin like slug,  not enough strength, and the cores wont "flip" and there will be no difference between having magnets on back of cores and having none at all...thats all I can think of right now - I can think of things out of box like two stage cap output circout and a run cap switching into coils,  and coil shorting and sereis connections of coils but I think it would be better to try and get what Ropmeor did to work first .... this is a really nice clean  little rig Woopy built wish it ran as good as it looks....this isnt going to be as easy as building a simple "kit" to copy that Romero providedd via internet plans before the hired goons showed up it looks like.
Maybe part of the deal with the goons was to not tell everything, and leave a bit out....who knows... but  sure would be nice if those those magnets behind the generator-coil cores do something dramatic in somebody's testing soon.
wings
from Adams motor :
http://www.totallyamped.net/adams/#top
"....... Put simply, IMHO, the acceleration effect is the result of negating oppositional forces associated with the generator core/current, and not the addition of extra energy into the system. This negation occurs due to a phase shift in the coil current and core counter-mmf, as a result of increasing frequency and /or higher than nominal output loads up to and including a short circuit.
Now I ask myself - why don't conventional closed system generators act like this, and accelerate under higher than nominal loading or short circuit? Can they be made to act in the same manner.? After all, even with Lenz's law applying, the coils of a conventional generator are bound by the same set of other accepted electrical rules which govern the Z impedance characteristics of an inductive power supply connected to a load.! And if they can't be made to have the same characteristics- then why not ?"
toranarod
Quote from: i_ron on June 03, 2011, 11:27:51 AM
The difference is Chevy parts have different dimensions and don't fit. IF the diameter was the same and the thickness was the same and the spline was the same you could use a Chevy clutch in your Ford.
The problem with doing an "exact" Romero replication is we don't know the oxygen content of the wire...was it oxygen free?
What is the mH of a coil?
R admitted his coils all had different number of winds... what number should we use?
What grade are the neo magnets?
Do you have to run it outside, within earshot of the London underground, for it to work?
Only if you can tell us the exact specifications of Romero's build could anyone have a hope of an "exact" duplication. And this is an impossibility.
Ron
As Romero is no longer available to support these projects I guess we have to hypothesize and read between the lines on what may have been the functional parameters of this motor generator. And who knows…we may end up creating a whole new machine or a very accurate replica. We may never know but the goal still remains the same - OU
i_ron
Quote from: toranarod on June 03, 2011, 02:23:04 PM
LOL, agreed, I was just trying to point out to the "exact replica" people
that when all the parameters are not known then to insist that we only build "exact replicas" is an oxymoron.
Ron
