Muller Dynamo
0 Members and 324 Guests are viewing this topic.
Hoppy
Quote from: teslaalset on June 11, 2011, 02:55:23 AM
@Bruce, I don't see the solution you see here.
From what I understand is basically two coils at the same clockwise position (as you indicate in your figures) are connected anti-series.
In that case EMF is cancelled out, but so is the current caused by that (Kirchhoff's law)
No current, no load power.
So, what am I missing here?
As I see it you are missing nothing. More current - less voltage. More voltage less current. Load the coil, for higher current less voltage.
Bruce, please draw out your diode 'solution' for self-running.
Hoppy
protein_man
Bruce, wouldn't hooking up the coils in your configuration with the diodes just cancel each other out and produce no useful power?
Arthurs
Hello everybody:
    Who can tell me: Romeouk whether there use the "coil short"?
    It is very important!
    This is related to whether we're on the right path.
    Thank you
bolt
No there is NO coil shorting on the mulller.
..And while im here Bruce's diode method is very imaginative but it will not work and does not universally apply to all or any other OU device.
romerouk
@Bruce_TPU
You've got the ideea!
People must be able to visualize and understand before starting any project. Use pen and paper(that is cheap) and don't spend money on parts and components unless u have no problem with that.
A specialized software program will help too but as u know these programs are built according to the existing known rules and inventions, many times are showing wrong indications.(I have seen wrong indications with my eyes)
@All
This month I have limited time to work and do experiments and I will take it more easy now.
I am still thinking to the best arrangement for my next project. All I have done lately is just testing and reconfirming some of my old experiments then I will take the best from the experiments confirmed.
Simple Example:
we have a rotor with NSNS and 2 coils, one to drive the rotor and one to collect.
the collector coil must have a core, any type but not air.
run it and measure the output of the collector and current going into the input coil
now to the end of the collector coil attach another core same type with the one used for the collector coil, same lenght too.
check the in and out - any change? good or bad?
check attaching only half lenght core - measure again ???
what about longer core.... measure again...
what about larger...?
this are simple  steps I take with most of my builds
I cannot teach you that, first make a list with what you think of and the rest comes while you work on the project.Write down every time you have discovered something, you leave it for later and you will forget.Write down all measurements.Check on the web too se if that has been observed by others.
All these requires a lot of patience and I am sorry to say it but not all of you have that.
The above experiment can be extended to a rotor  with all magnets NNNN or all SSSS and attaching small magnets or ceramic at the end of the extended core.
Now just a small tip for small projects: Zener diodes...
@Plengo
In my old underservice forum I had the ideea where every member on the forum will have his own channel where can post the work, pictures... something like the facebook or twitter but it can be done even here but only for people who will really show their work, even not very important thinks might be useful for many others.
Do you remember that youtube video posted by gotoluc some time back where he moved a magnet in front of the 2 microwave transformer coils? Well, that was a good inspiration for me and took it further. All I can say now is, thank you gotoluc!
As I read recently, even to show how to drill a hole in acrylic is very important for some, not everyone has good tools and can be shown to be done in easy steps and basic tools.
We all wish to have Clanzer machineries but unfortunalely many of us don't have enough funds even for proper living...
that is enough for now
Best Regards to all,
Romero
